It could only need some soldering of the display itself. If you want to try it your self.
remove the top cover (you may need to remove the front panel also)
- inspect the twenty or so pins of the fl display tube especially the end ones (resolder if bad).
- if they all look good check for DC voltage on the end pins (20 to 30 volts)
be careful not to touch the transformer pins when unit is pluged in and the cover is off!
