Averatec 3360-EH1 Notebook Logo
Anonymous Posted on Mar 09, 2012
Need Averatec drivers
Reinstalled XP after system would not boot. However wireless driver, soundcard, and some others are missing: Base System Device PCI\VEN_1217&DEV_7110&SUBSYS_061014FF&REV_00\4&22270378&0&2AF0 The drivers for this device are not installed. Multimedia Audio Controller PCI\VEN_8086&DEV_24C5&SUBSYS_041014FF&REV_03\3&267A616A&0&FD The drivers for this device are not installed. Network Controller PCI\VEN_8086&DEV_4220&SUBSYS_27018086&REV_05\4&22270378&0&20F0 The drivers for this device are not installed. PCI Modem PCI\VEN_8086&DEV_24C6&SUBSYS_100714FF&REV_03\3&267A616A&0&FE This device is not configured correctly. Video Controller PCI\VEN_8086&DEV_3582&SUBSYS_031014FF&REV_02\3&267A616A&0&11 The drivers for this device are not installed. Video Controller (VGA Compatible) PCI\VEN_8086&DEV_3582&SUBSYS_031014FF&REV_02\3&267A616A&0&10 The drivers for this device are not installed. I do not have any of the **** recovery disks and there is NO support for this piece of ****. Been searching online but no luck so far. I don't want to purchase any software (Driver Detective, etc.) either. Help pls....
  • Anonymous Mar 10, 2012
    Btw, it's an Averatec 3360-EH1...
Anonymous
Level 2:
Sergeant:
  • Expert 285 Answers
  • Posted on Mar 10, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
285
Questions
5
Helped
58375
Points
909
U CAN ONLY GET DRIVERS FROM THE MANUFACTURE WEBSITE
Need the driver for Averatec 2100 Wireless
Go online and type www.google.com In the google search box type: "Averatec Support" (without the quotes). Look for Drivers and Downloads and click it. Enter your computer model and operating system when requested. Download and install the Wireless driver.
4helpful
I am having difficulty obtaining drivers O 3000 N100 OS XP Base System Device PCI bus 5, device 6, function 2 Base System Device PCI bus 5, device 6, function 3 Base System Device...
Base System Device drivers are usually installed by what the manufacturer calls "Chipset" drivers. If you are running Windows XP, there is an Intel Chipset driver available at the Lenovo Support Page for your model. If you are running an Operating System other than Windows XP, I would go to the above page and compare the drivers listed there with what you are seeing in Device Manager. Install the ones that are missing. Hope this helps!
2helpful
2answers
3answers
2answers
How can i get drivers for my 5100 averatec install xp pro and now all drivers r missing no sound or video
THE ONLY WAY TO GET BACK THE PROPER DRIVERS SO YOUR SYSTEM IS UPDATED AND RUNS CORRECTLY IS TO DOWNLOAD OR SEND 4 A DRIVER RECOVERY DISK FROM EITHER YOUR PC'S MAKER OR XP PRO..COST IS USUALLY AROUND $50 BUCKS!
Reinstalled vista on Dell E521s but lost network connection.
Does in system hardware configuration the network adapter show up with a driver attached to it?
Recover disk/partitions not only includes windows but all further necessary drivers for such PC then windows provides. Graphic adapater, soundcard, networkadapter.
If there is a unrecognized networkk adaptor there type 1394 you should get to know which driver it needs.
This is why I dislike Dell PC's allways. You own one, they own you together with Microsoft
1helpful
Wireless network
I don't think Vista has a working driver for the T2000 because it was designed for XP..Unless you upgraded the XP you had to Vista.You should install XP back on the laptop then go to (www.mpcdrivers.com)where you can get the exact drivers for your base unit and the XP operating system.Putting XP back on it, is really the only sensible thing to do, to ensure all hardware will be installed ,especially the biometrics.Thanks
Internal Wireless card will not activate
Most likely you need to install the driver for the NIC card. Go to Device Manger under System Properties and see if the Wireless NIC is showing a driver error. If so right click, select Update Driver and navigate the the file on the CD. Once the driver is installed if should function normally.
5answers
Soundcard missing on my computyer
i miss my sound card.i need to install the sound card driver
Top Averatec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
