Started happening a couple weeks ago if the lid was lifted during the cycle at any point, cycle would stop. Now I can't get it to anything but fill with water.
SOURCE: My Whirlpool washer model #LSQ9544KQ0 will fill
You may have a broken motor coupling. Failure to agitate or spin accompanied by a loud noise are some of the symptoms you can experience with this problem. Just to be sure...the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If you determine the coupler to be defective, the next link explains how to access the coupler and replace it:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included in the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this helps you.
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
SOURCE: Whirlpool LSB6300PW2 Won't Agitate or Spin
if you lift andclose the lid do you hear "clicking" noise??? i bet not. simple repair, lift the lid and with a hollow shafted screwdriver(1/4in nutdriver or similliar hollow shaft implement)you fell with your hand the bottom half of the left side lid hinge. as you open and close the lid you can fell the opposing end of hinge under the top no need to dissasemble you can fell it right there. when you find it simply slip the hollow ended shaft over the hinge and apply pressure towardds the rear of unit.While doing this the top will want to close( your pushing against the hinge).. after appling slight pressure youll bend it slightly, enough to activet the lid switch mounted to the rear of the main lid assy.
SOURCE: Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
SOURCE: Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
