Water is not heating up and the machine is going through its cycles and when finished the delf is still wet.
SOURCE: Zanussi DE540X Dishwasher
value of 26 ohms is about right. how hot does it get? max water temp is about 65 degc
SOURCE: How to replace heating elemant on Zanussi DE6850 Dishwasher
is your water heater set on 120 degres
SOURCE: I have a Zanussi ZSF 6160 dishwasher which is not
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
SOURCE: Dishwasher not heating Zanussi
Hi, I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
lmnbv
