20 Most Recent Zanussi 18 in. DA4342 Free-standing Dishwasher Questions & Answers
My zanussi DA4342 lets the
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
9/11/2011 7:18:32 PM • Zanussi 18 in.... • Answered on Sep 11, 2011
My dishwasher isn't rinsing properly,
heatman101
5/5/2011 2:37:23 AM • Zanussi 18 in.... • Answered on May 05, 2011
Not cleaning properly
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems indishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
9/25/2010 5:00:37 PM • Zanussi 18 in.... • Answered on Sep 25, 2010
Dishwasher not fully pumping out at end of cycle ,
check the control timer and inlet solenoid valve
6/4/2010 8:23:15 PM • Zanussi 18 in.... • Answered on Jun 04, 2010
Hi there
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
7/4/2009 9:14:57 PM • Zanussi 18 in.... • Answered on Jul 04, 2009
No water getting to washer
Yes, but I would check to make sure power is getting to the valve before replacing. Usually if you hear a buzzing, then power is going to the valve. The best way is with a meter on A/C setting then put it on OHM setting to check the solenoids on the valve. I would buy a meter at an appliance parts store so they can show you how to use it. It's not that difficult and everyone should have one.
11/30/2008 11:44:01 AM • Zanussi 18 in.... • Answered on Nov 30, 2008
Tablets not dissolving
Sounds like whatever soap you are using is just too much soap your dishwsher can handle. The soap "packs" are usulally an overload of soap for most dishwashers. Just a few teaspoons of regular name brand soap sometimes will cure lots of dishwsher ills!!!
4/12/2008 12:48:27 PM • Zanussi 18 in.... • Answered on Apr 12, 2008
Zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
1/12/2008 7:10:14 PM • Zanussi 18 in.... • Answered on Jan 12, 2008
Upper spray arm came off
I have the DA4142 and if its anything like mine, the upper spray arm simply clips into place under the upper tray rack.
11/6/2007 6:55:51 AM • Zanussi 18 in.... • Answered on Nov 06, 2007
2answers
Zanussi DE4744 not heating at all
exercise to lose belly fat; fat loss extreme; workouts to lose belly fat; best foods to eat to lose weight; diet for weight loss for female; dr now diet plan; simple 1200 calorie meal plan; meal plan for weight loss and muscle gain female; 1200 calorie a day meal plan; lifting weights to lose weight; foods to eat to lose weight; lunch for weight loss; healthy lunch for weight loss; healthy foods high in fat; https://behealthyideas.com/ <ahref="https://behealthyideas.com/">https://behealthyideas.com/</a>
1/18/2023 11:10:53 AM • Zanussi... • Answered on Jan 18, 2023
Zanussi ZDLN1512 Dishwasher Anti Flood Warning - How can I fix?
If it is new, it is under warranty and if you try to fix it, it will void the warranty. The water in the flood tray comes from the machine itself, normally from hoses or on an older machine pump seals. Page 17 refers and confirms https://manualzz.com/doc/53457617/zanussi-zdln1512-user-manual Call for warranty service to fix the fault free of charge.
8/21/2022 4:41:25 PM • Zanussi... • Answered on Aug 21, 2022
2answers
Zanussi ZDF231 top spray arm is not turning, is it a pump fault?
input to pump clogged output clogged pump bad or just dirty inside. leaks end to end that path, In and output.
8/2/2022 11:19:44 AM • Zanussi... • Answered on Aug 02, 2022
Zanussi ZDF26001XA code .30 anti flood device. how do i fix it without calling a mechanic?
Under the base of the machine, above the floor there is a tray with a sensor in it and that is what triggers the Flood Error Code. So the machine needs to come out, the back or side panel removed and the tray thoroughly dried. You also need to find where that water came from. If the salt container is in the base, it may be leaking if you were breaking up the salt.
11/30/2021 4:42:10 PM • Zanussi... • Answered on Nov 30, 2021
Zanussi 18 in. DA4342 Free-standing Dishwasher Logo
Popular Tags
29 questions posted
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Dishwashers
  • Zanussi Dishwashers
Most Popular Question
dishwasher isnt rinsing properly
  • Dishwashers
