I am having problem setup the indoor antenna for receiving digital channel on this TV. When I setup to "TV" and "Air", and tried to go to scan the channel using antenna at the "Setup", I saw the "Antenna Setup - DIGITAL" is grayed out. I can not scan the channels on this TV for receiving digital TV channels with antenna. I've seen a few similar postings online. Does anyone have experience on this with solutions? Thank you!
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
SOURCE: lc-32pd5x its a roof mount antenna not sure what
so you could not wait 1 minute while I wrote to you how to reset it?
by default from factory the pin code is 1234
heres the full user manual for your tv
http://www.cleverhome.com.au/user/Sharp-Aquos-Piano-Black-LC37PD5X-LC32PD5X-manual.pdf
if the code doesn't work heres how to reset the tv
HOW TO SET THE FACTORY PRESETS
Turn off the TV by pressing POWER on the TV.
After waiting for about 1 minute, press and hold down RESET and press POWER on the TV to turn on the
TV.
All setting items (except TV channel) return to the factory presetting.
note Password will be cleared after running the factory presetting operation.
You can run the Auto Installation again by using the following steps.
1 Turn on the power of the TV.
2 Press MENU. (Make sure the menu screen displays.)
3 Press left or right to select “Setup”.
4 Press up or down to select “Auto Installation”, and then press ENTER.
5 Press left or right to select “Yes”, and then press ENTER.
SOURCE: cannot change input from antenna to cable as it is
Normally, the cable input will only be available if a "live" cable or satellite box is connected to the other end.
You may also have to go through a setup routine to enable the cable input. Please check your manual.
Testimonial: "solved the problem thanks"
SOURCE: Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Testimonial: "Thx for your help, I wondered if tou thought If I could put an outdoor antenna on our balcony, seeing as I have no roof access and another apt. above "
