20 Most Recent
Sharp Aquos LC-13E1U 13 in. EDTV LCD Television Questions & Answers
How do I attach an antennna?
On the back of the TV look for the connector marked Ant/cable. This is a silver connection with threads on it. If you have a digital indoor antenna, connect it there. Same goes if you have an outdoor antenna. Now go to the setup screen and select AIR for antenna type. After that do a channel search and select digital and analog channels. Let the TV find all the stations it can. When it's done searching, it will show a picture. You may need to aim the antenna to get a better picture .
V-chip is locked on tv
1 Press MENU to display the MENUscreen.2 Press Up/Dn to move the cursorto V-CHIP BLOCK, and press> /< to enter.3. Press and hold both CH UP andVOL UP on the TV set simultaneouslyuntil the message INPUTSECRET NO. blinks.4. Press MENU to exit.
Sharp TV LC60LE745U the screen remained black and an arrow on the bottom of the TV stay blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
