i plugged it in then it turned on. i tried to go to menu and listen to some song s but it staid on the same menu help mei plugged it in then it turned on. i tried to go to menu and listen to some song s but it staid on the same menu help me
You can't post conmments that contain an email address.
Just leave it until the battery runs out and it turns off by itself. Then plug it in and charge it. Once it's charged, turn it off. Then wait at least an hour before turning it back on.
Have you tried resetting it? Try holding down the menu and middle buttons at the same time and the ipod should reset itself. Also check and see if the hold switch is on. You need to make sure that it is off in order for the buttons to work.
Learn to reset the device using the method shown on your manual. You can also connect it to the computer to scan the files for any corrupt inactive ones and delete them. i think resetting should solve this issue.Helpful ? Good day
On the bottom where yuo plug it into the computer there is a Reset. Stick a pin or pencil in there to reset. It may work. Did for me when my friend borrowed it to go jogging in the rain.
my mp3 player is just showing a blank white screen. it wont turn on, wont turn off, my computer wont recognize it, nothing. whats going on and how can i fix it? thanx. anything will help at this point.
thanks dw [email protected]
Ok. You have reset your device, there is a reset hole next to the DC-in hole.
Then if it still not working then you have to ask for a new lcd screen/ lcd screen module.
That means the LCD of your MP3 Player isn't working anymore.
Good Luck
the coby mp-705 will not turn off and stays stuck on sreen
