Minolta bizhub 200 Copier Logo
A
Anonymous Posted on Jan 23, 2012
Bizhub 200 has error code c3452
Error code c3452 is displayed on screen
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 19, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1914057
Points
11960
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2 Related Answers
Anonymous
  • 17 Answers
  • Posted on Jul 11, 2009
SOURCE: Bizhub 200
problem in hv unit ( ch corona ) in drum unit replace if necessary
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Aug 02, 2009
SOURCE: error C3452 right after power on.
I assume this is a Bizhub, Fusing unit fault. to clear you will need to look on the right side of the machine, if this machine is networked?, just below the scanner, on the right side is a small cover it will come off close to where your network cable goes. once it is open press the small black button (Looking at the machine from the right side it will be on your left using a paper clip or small screw driver just gently depress the button the machine will go thur its cycle you will get a Trouble reset on the screen with a "OK" touch then power off, wait ten seconds then power on
Bizhub 200 erro code c3452
Its related to Fuser Unit,
Try to reset by Switch On Main Power switch by holding Utility Button for 10-15 second.
Troublereset Option will appear
touch it
switch off again and on in normal way.
How do i solve error code c3452 for bizhub konika minolta
remove the network cable, right next to the network connection is a cover remove it. there is a small black button, using a pen push it then watch the control panel it will goes thought certain screen watch for one with a small . in the center on the left side when you see it press the "3". let it go to the code. Then press the counter switch, will see a new icon "Maintenance Mode" press it the press trouble reset. let the machine go though screen again this time let it go to ready to copy if the code come back replace the fuser unit the HOT part, do not reset again you messing with the fuser which can catch on fire, that will ruin a perfectly good day
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Error c3452
error c3452 is fusing warm-up failure.
first do trouble reset.
second, check H1 or H2
third, check TH1 and TH2
four, change new fusing unit
five, change PU
six, change PWB-A
1helpful
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
2answers
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
2answers
C3452
hi ali... the problem with your mfp is fixing uunit warm up failure... try to perform trouble reset... turn off the machine, then hold press the utility/ counter... konica minolta logo appears... press 3, type eight 0's then then tuoch "end" then touch "trouble reset"( note: dont touch other menu displayed on screen because you might get another problem.) then the machine will re-statr.....If there is an abort code, there its time for you to change the fixing unit.... ( if you know electronics try to check the heater lamp and thermostat using a multitester, check if there is a continuity inthe both ends...)
8helpful
When I turn on the machine (bizhub c300) error code c3452 appears, within 20 secs, How do I reset this code
This is a fuser related code.
To reset the code, please do the following
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Good luck
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
