Camera icon/folder not showing up on my mac when the camera is connected via usb
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
SOURCE: i am not gettin any
Check your settings in the menus. If you've muted the camera to remove the other sounds, it will mute the video soundtrack as well.
SOURCE: Canon Ixus 130 gives message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
SOURCE: E32 error with canon ixus 130
I have purchased recently canon ixus 130, the camera automatically shuts down after some 30 sec& shows a messege 'camera error,restart camera will autometically shut down error
E32.'
SOURCE: can i use my canon
No. The IXUS 130 is designed to store images (and videos) to memory, not to stream live video to another device.
SOURCE: my new gopro camera is not recognized by my mac
You need to push the POWER/MODE button once it is connected and the red charging light is on. It will then say "usb" and will show up on the desktop for you.
