20 Most Recent Nikon Coolpix 5200 Digital Camera Questions & Answers
I am NOT an expert on this problem as I have never changed languages. Language is typically in the TOOLS menu (Wrench) It you get to settings and English is greyed out then I am stuck. If you have many settings you want to keep please ignore what I say here. One workaround that MAY work is reset to factory settings. It could be one of your settings that keeps language setting greyed out. A reset makes the camera like you just purchased it new.
Nikon Coolpix... | Answered on Nov 06, 2019
You Can Use the Google translation http://translate.google.com/ or Bing translation http://www.microsofttranslator.com/ to translate the common words about camera menu to the language of your camera now (As some LANGUAGE can't be type by latter such as Chinese, Japanese and so on), and to make a right setting.
Nikon Coolpix... | Answered on Jun 26, 2018
If you can read the SD card with your computer, copy (backup) all images on the card to your computer. Make sure you saved ALL images. Then put the card back in the camera and FORMAT it. It is in the TOOL MENU that looks like a WRENCH.
Nikon Coolpix... | Answered on Mar 02, 2017
digital heaven perhaps did you unlock the sd card before trying to upload .small switch on the side of card .
Nikon Coolpix... | Answered on Aug 28, 2015
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Nikon Coolpix... | Answered on Jul 10, 2014
Put battery s in camera put sd card in slot problem solved
Nikon Coolpix... | Answered on Jun 03, 2014
Remove the lens cap and lens hood, if present. On the front of the lens is a threaded mount, like the mouth of a jar. Just screw the filter on, like screwing a lid onto a jar.
Nikon Coolpix... | Answered on Mar 11, 2014
When you want your camera repaired, option one is contact the Nikon service centre closest to you.
Option two, if you want to do it yourself, goto ifixit.com. There you find lots of videos books and pictures about electronic repair. Perhaps your camera is there too, or one that looks the same. On that site you also can order spare parts and tools if you need so.
Nikon Coolpix... | Answered on Jan 30, 2014
It's brand new - take it right back and get it exchanged for a working unit!!!!!!!!!!!!!!
Nikon Coolpix... | Answered on Jan 21, 2014
The 5200 was designed primarily as a still camera, storing images (and videos) to memory. It was not designed to function as a webcam, streaming live videos to another device.
That probably wasn't the answer you wanted to see, but there it is.
Nikon Coolpix... | Answered on Jan 10, 2014
Sorry, the 5200 is limited to a three-second or ten-second delay with the self-timer, and there is no provision for remotely triggering the camera.
Nikon Coolpix... | Answered on Nov 30, 2013
Nikon Coolpix 5200 Digital Camera Logo
114 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
fit filter 18 55mm lens
  • Cameras
