Just need a few solutions in regards to this issue, I have tried the control panel< Personalization< display and selectiong 2 but that does not seem to work
SOURCE: Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
SOURCE: When I hook my ps3
Turn the system off, then push the power button for 5-10
seconds. That resets the video to the minimum setting.
Or
*WITH NO DISC INSERTED* If there is one, eject it and turn the system
off so I can show you from a system start with no disc. This IS using a HDMI cable as well
1)Power on system; do NOT push any buttons on the controller!
2) Over 4 to the left
3)9 down
4) Click 'X' once
5)Click 'X' again
6)Click 'X' again
7)Click 'X' again
That should bring you to some settings list that makes sure that the settings you clicked were what you want.
Good luck.
