I own one. Most have a plug in the top of the trans/hydro case to the left and rear of the gear shift leaver. It takes a 3/4" drive to open it. I use an extention and brake bar or ratchet. The fluid should just all most reach the opening. the books state it should hold 8 to 10 gal. I have found my 460 Utility holds almost 20 gals.
SOURCE: what kind of hydraulic fluid can i use in my
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
SOURCE: where do fill up hydraulic fluid on a 1490 case
backend by the linkage someware, sory but dont know what oil to use
SOURCE: Hydraulic Fluid Level (Checking and Filling)
hello darrell. yes you just unscrew the plug and fill it full.
SOURCE: is hydraulic fluid really used for both the
caseih hytran fluid is used for hydraulics and transmission fill through plate on top of deck next to shifter check plug is located on left side of transmission housing next to clutch linkage rod probably square headed pipe plug
