I have a Samsung SU2920. The pedal has broken. Spare is available on espares. To remove the broken pedal:
Turn the machine over and locate the foot pedal side near a rear wheel.
Operate the pedal to see how it is held in place by a moulded pin which is captured by two lugs on the underside of the body. Use a torch to get some light in there.
Insert a thin blade on either side to bend the plastic lugs slightly so that the moulded pin on the foot pedal can slide upwards without being held by the lugs. The pedal will not slide up easily. I used a hammer and a metal bar to tap it free.
Once the pedal is removed, the spare can be clicked into place from the top without tools.
SOURCE: Handle foot pedal release U6425-900
If you look under the vacuum where the latch is located, it is held in place by tabs on either side of the latch. The latch had a pin that holds it in place. You need to insert a small flat blade screwdriver to bend these latches back carefully to release the pins. Once the pins are freed, the latch can be pulled out the top. The replacement should be installed in the same orientation by pushing in from the top until the pins on the latch snap into place.
SOURCE: Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
SOURCE: Kenmore 31913 Foot pedal release lever broken-need to replace
FixYa techs - thank you for your response but I solved the problems. It took me 2 hours of continual searching but I finally found the parts - listed under the tab sew machines of all things!? There is one pedal in stock and I called the service company and will pick that up and do it myself. I took that part off my vac and put it back on so know I can do it. I've been fixing stuff all my life and it just takes some logic - anyone can do it if they have a tool kit.
SOURCE: pedal does not engage anymore
I have the same problem. You will need to replace the handle release pedal, part number 8174899, $7.99 plus tax & shipping. Check with Sears Parts. It's a single screw that holds it in place.
SOURCE: foot latch is broken. need to replace with new
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
