Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
Paul Phillips Posted on Dec 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have ryobi 137r . i cannot ge the head off to replace the string
Oingo
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Dec 12, 2014
Oingo
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
4699
Points
26
Take a large adjustable wrench and grip the bump head (black plastic) at the same time use your other hand to hold the line spool (orange plastic) rotate the the wrench in a counter clockwise direction slowly and carefully to ensure you are not applying force in any other plane than parallel to the spool or you may damage the bump head threads just until it breaks free. Remove the rest of the way by hand. This happens to me from time to time. If you care you can put a small amount of graphite on the bumphead threads to allow it to come off with hand pressure.
Anonymous
Level 2:
Sergeant:
  • Expert 316 Answers
  • Posted on Feb 17, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
316
Questions
0
Helped
132116
Points
531
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,don't forget to give 4 thumbs up,any comments welcome,thank you, ``
1 Related Answer
Anonymous
  • 115 Answers
  • Posted on Jul 06, 2009
SOURCE: Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Ryobi RY40002 String Trimmer motor runs slowly and rough
Question edited to add FULL make model (what it is).
Category moved from Washing Machines to Ryobi Trimmer.
Replace the spark plug. Strip and clean the carburetor. Replace the fuel with fresh. But hang on though, the RY40002 is electric and runs with a 40 volt battery, so no spark plug and carburetor! :>D Replace the battery, lubricate everything from the motor to the head. Check the motor with nothing attached to it. The carbon brushes may need replacing or its bearings need greasing.
Ryobi RY40002 40V Power Head and RY15523A Expand-It ...
https://www.walmart.com > ... > All Trimmers and Edgers
Includes (1) RY40002 40V Power Head and (1) RY15523A Expand-It Trimmer Attachment · Compatible with All Ryobi 40V Lithium-Ion Batteries (Sold Separately) ...
US$119.90 · ‎Out of stock
Ryobi gas powered string trimmer
head threads are left hand thread so in effect you have to "do it up" to unscrew it
Remove ryobi S430 trimmer head
it has a left hand thread which means that to unscrew it you have to turn it in a clockwise direction like putting a nut on a bolt
Automatic line advance not advancing on Ryobi 18v trimmer
I have a Ryobi Model RY28040 straight shaft line trimmer. In my case I replaced the complete String Head Assembly that includes the String Head Housing, Spring, and Spool and the string still did not advance. I then discovered that the bolt in the Spool Retainer cap (the red cap that attaches the spool to the shaft) was fused and not moving. The bolt needs to be loose inside the cap in order to allow the spool to move in and out by the spring. I loosened the bolt and fastened the spool back onto the shaft. Fired it up and bumped it a few times and the line began to advance. Turns out I probably only needed to replace the Spool Retainer rather than the String Head Assembly.
5helpful
I inherited this trimmer and do not know how to add new string. There isn't any kind of a manual that we can find. The trimmer is a RYOBI 137R. Thank you.
hi i have a ryobi rlt 30cd strimmer and when i was useing it it just stopped it as fuel in it but ive cleaned the carb but i still cant get it to run as any one got any ideas thanks
2helpful
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
1helpful
The electric motor on my Ryobi 137r string trimmer is vibrating, rattling, and has lost power. It sounds and feels like worn out (binding?) motor bearings. Are they available as a replacement part? What...
You likely are spot on with the diagnosis of bearings. But, I would hesitate to say that they are replaceable. Contact a local electric motor shop (alternator, starter, etc) to see if they would be able to change the bearings, and perhaps the bushings as well.
How do you remove the old string head to add replacement?
untwist the nut at the bottom of the spool head to replace the string
Jul 05, 2009 • Garden
1helpful
3answers
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
