I've done this before with no problems, however this time was different. I conected a small hose to the drain valve and started to loosen to the flow. Water was spitting out of the fitting and flow was slow. I contiuned to open the valve and eventually went to far until it came off. Had to shut down the lines and let the tank empty enough to replace the valve. Then turned on the water lines and thought I was back to normal, But even after recovery time we now only get small amount of hot and mostly luke warm water. Pilot and burner seem to be working fine. During the water outburst I did somehow knock off the red dial on the gas control thermostat. I have it running as hot as it will go to get even warm water. Should have left the damaned thing alone I guess!
The dip rod in heater may have failed. did you see any white chips in sediment while draining. if so its the dip rod, they do fail sometimes. If the water heater in your home was built between 1993 and 1996 and you are beginning to find small pieces of plastic in your faucet aerators, shower nozzles and washing machine supply tube, or if your water temperature is suddenly not as warm as it used to be, the source of the problem may be your water heater's dip tube. The purpose of a dip tube is to carry cold water to the bottom of the tank, where it is heated for use. The defective dip tubes tend to crumble and disintegrate into the tank. Over time, its plastic ! have a very good day !
