In involved fuses #5 & #10 15 amp in main fuse panel
from Ford Service cd
http://www.fordcds.com/
Fault Code 12
Air Bag Deployment Circuit Drop in
Battery Voltage
Circuit Description
Normal Operation
The diagnostic monitor measures the voltage at pin 13 of the diagnostic monitor connector. Voltage at pin 13 should be equal to battery voltage. If the voltage measured at pin 13 drops to less than 9 volts, the diagnostic monitor will flash out code 12.
Possible Causes
A drop in battery voltage at diagnostic monitor pin 13 can be caused by:
1.An open circuit that would prevent battery voltage from reaching diagnostic monitor pin 13.
NOTE:
If the instrument panel fuse and/or the power distribution fuse are blown, be sure to diagnose the system for possible causes 2 and 3 below.
2.A short to ground in Circuit 611 (W/O) or 612 (P/O) may result in a blown instrument panel fuse and/or power distribution fuse.
3.An internal short to ground within the safing sensor may result in a blown instrument panel fuse and/or power distribution fuse.
4.A problem in the charging system causing battery voltage to drop below 9 volts.
