Q - My washer seems to keep filling with water, the water keeps coming in the washer and going out the drain without the washer motor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned
from your description of the problems, it seems that the drainage valve is on. This is an electronic valve.
Seems that the valve is faulty and you may have to fix it.
The best way is to get a technician to fix it.
It also explains the spin cycle problem, as spin cycle doesn't start untill all the water are drained by the drainage/outlet valve.
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
The tranmission is out causing the pump to drain all the time
hi
this sounds like a syphoning problem this means the outlet /drain pipe at the back of the machine has been pushed to far into the drain upstand pipe causing the water to syphon straight through the machine make sure that the drain pipe is only part way down the drain pipe, hope this works for you
cliff
What exactly does "the transmission is outcasing the pump" mean? I wasn't aware that front loaders had transmissions. IF SO, EXPLAIN HOW TO FIX, or could it also be something else?
Thanks
Most of the solutions given are for top loaders. Mine is a Bosch 2100 front-loader. Do you have any more detailed solutions for this particular model?
Makes sense, I'll troubleshoot according to your drain-valve recommendation.
Thanks
I unplugged, bypassed the drainage valve, seemed to make no difference. Also the motor did run momentarily (both directions) so it must be ok. One other thing I did notice is that when I start the wash cycle and the water starts to fill, it only fills for 10 or 15 seconds, not even enough water to come up to the bottom of the tub level, then of course, the drainage valve kicks on and drains it out.?????
Could this be a circuit board problem? No error codes though.
Could the circuit board be faulty and causing these eratic cycles?
cleanout pump put all back together water turned on and no water filling drum
