Televison & Video Logo
A
Anonymous Posted on Nov 27, 2011
3 digit code for LG television model 21FX4AG-TD
Anonymous
Level 3:
President:
  • Master 2,923 Answers
  • Posted on Nov 27, 2011
Anonymous
Master
Level 3:
President:
Answers
2923
Questions
0
Helped
730653
Points
8409
Kindly try each one of these codes:
065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275.
If none of the codes work, then you may need to add zero in front of each codes.
Thank you!
Cannot program LG TV to my remote. None of the codes work and it won’t allow me to manually program a code
If this is a Universal Remote, nobody does that any more. Buy a facsimile remote made for you LG television.
Google
make model replacement remote.
They should all allow you to enter codes manually. Send it back as faulty.
3 Digits Universal Remote Control Codes For LG TV
  • 520.
  • 512.
  • 506.
  • 505.
  • 627.
  • 615.
  • 653.
  • 766.
More items...
May 15, 2020
LG Universal Remote codes and Programming for TVs
I have error code of SC361-2 for MPC3002, what shall do is because of the magenta pump error or drum unit TD sesnor problem, what shall do
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC3002&code=361-02
Quoting from link above:
Ricoh Aficio MPC3002 Error Code
Code
361-02
Description
TD sensor (Vt high) error 1: C
• The Vt value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 4.7V) with SP3-020-002 for twenty counts. • The [Vt - Vtref] value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 5.0V) with SP3-020-001
Causes
• Black, magenta, cyan, or yellow TD sensor disconnected • Harness between TD sensor and PCDU defective • Defective TD sensor
Remedy
1. Check the black, magenta, cyan, or yellow TD sensor connector and harness between the TD sensor and PCDU for damage. 2. Check the drawer connector. 3. Replace the defective PCDU.
My LG lcd TV model no 42LV3730-TD suddenly not turning on. Some one suggest me to replace the main mother board, if that is the reason where i can find this parts?
Check for bulged capacitief in the Power print, very common thing in this type, replace m for around 10 dollars and enjoy your tb again.
Code error "6E" on Dryer LG td-c70210e
ok so 6E means that your thermistor is out of range
Nov 23, 2012 • Dryers
Code for 37LH3000ZA LG TV
Hello
Get into this link. Enter your TV model number and all details. You can get the code for your Tv frm here.
www.sky.com/.../remote.../operate-tv-with-sky-remo... - United Kingdom
Front LED just Cycles white then goes red. Replaced lamp did not fix set. Found 5 volt power on command missing from Digital bd to DMD bd. Need to replace Digital main bd. Part needed is 6871VSMS28B. Will...
Good day!!!
if the command signal from main board to DMD board missing the problem could be the main board..
I already found the board online for only $75 on this site http://www.discounttvparts.com/6871VSMS28B_p/td-1169.htm
$100 on this site http://www.ebay.com/itm/NEW-LG-MAIN-UNIT-6871VSMS28B-6870VS2273C-/260877125964
Hope it helps..
just add a comment for any follow up questions..
Thank you
I have a LG model 32FS4D-TE but a univerdal remote but lost the four digit code can you please give me some codes to try.
Eack brand of the remote uses its has its own codes. What is the make and model of this universal remote that you have?
Please repost the question again with more details so we can help.
32helpful
2answers
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
What is the 3 digit code to remotely control the LG42LB9DF by LG
They are all diffrent depending on the remote you are using. Some are 4 digit as well Try Vizeo codes as well. Same company.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
