SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
SOURCE: I have the error code 5 on the Ariston washer
hello,
what this mean is that the error code 5 indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). in your drying machine.
thank you.
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
SOURCE: Hi, i have washer /
Check the water supply, inlet valve, and hot & cold hose connections.
Got this piece of advice from their site..
Hope this helps.. :)
SOURCE: I need a door handle
Hi You can buy the parts at this link. Hope this helps...please
post back for further assistance. Daniel
