20 Most Recent
Hotpoint-Ariston ARWDF129NA Washer Questions & Answers
I have an error f13 could you help me?
Generally the F13 code refers to a water inlet problem, I would get the inlet manifold valve checked, or stating the obvious, is the water turned on and make sure there is no restriction in the hose behind the machine.
Need part number for door glass replacement Ariston ARWDF129NA
it is the whole door and glass. C00277532
check this link http://r.search.yahoo.com/_ylt=AwrBT8FtQthU9zQASwhXNyoA;_ylu=X3oDMTByMG04Z2o2BHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkAw--/RV=2/RE=1423487725/RO=10/RU=http%3a%2f%2fwww.guaranteedparts.com%2fpicture_library%2fAriston%2fARWDF129NA.pdf/RK=0/RS=MKzVwRgG.yYF8eJHJVxrlf8MM_U-
Wont start, no error codes, what could be the problem?
I would check the lid switch.
These switches are normally made of plastic, and are made really cheaply, and break often.
When they break the washer will no longer start.
Have someone raise the lid and check it out.
God bless your efforts.
"AQM9D49USK"
My washer/dryer doesn't fill
Hi
If the washer won't fill you'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
My top loader Hisense washing machine doesn't wash but it spins, what is the possible solution?
If your Hisense top-loading washing machine is not washing but can spin out the water, it could be caused by a few different issues. Here are a few things you can try to fix the problem:
- Check to ensure that the washing machine is properly loaded and balanced. An unbalanced load can cause the machine to stop working or not wash properly.
- Check the water supply to the machine. Make sure that the water hoses are properly connected and that the water supply is turned on.
- Check the detergent dispenser to make sure that it is not clogged. A clogged dispenser can prevent the detergent from being dispensed and the machine from washing properly.
- Check the lid switch. If the lid switch is faulty, the machine may not wash but will spin out the water.
- Check the water level switch. If the water level switch is faulty, the machine may not wash properly but will spin out the water.
- If the problem persists, consider contacting Hisense customer service or a technician for further assistance.
It's essential to note that if the machine is not washing but it can spin out the water, it could be caused by a malfunction or damage in the water level switch, the timer or even the motor.
