An E0-F2, could be a faulty temperature sensor, could be a faulty control board.. or could be a faulty touchpad. If the temperature sensor in your oven is good-- Contact http://www.FixYourBoard.com for help with your oven control board and/or oven touchpad.
512-355-1108 or [email protected]
Hello Sonya,
The E0-F2 error code means that the oven temperature was higher than it's supposed to be. Usually the oven overheats because of a defective oven temperature sensor and the sensor should be checked. this is what the sensor looks like...it is located within the oven chamber(usually in the left side) to check it,it needs to unplugged and using a mulitmeter set to measure ohms,check the sensor to be between 1060-1100 ohms at room temp. if the sensor is way lower/higher that 1060-1100 at room temp the sensor is bad and needs to be replaced, if the sensor is within that range then the control board is the problem.
GENE
