Lens stuck on our LX2 again, had it repaired first time this is the second time and it is now out of gaurantee. Judging by the number of very similar posts, it is obviously a well known issue with this camera. I think it's probably time to replace it. It won't be manufactured by Panasonic.
Thanks for the link which may,,,have solved the problem! I take it all back, seems there is a problem with all compact cameras with these type of lenses. After tapping the lens on my desk. a small but significant amount of Le Touquet beach fell out of it! Don't know if I got it all out but it's working again now. Thanks a lotThanks for the link which may,,,have solved the problem! I take it all back, seems there is a problem with all compact cameras with these type of lenses. After tapping the lens on my desk. a small but significant amount of Le Touquet beach fell out of it! Don't know if I got it all out but it's working again now. Thanks a lot
You can't post conmments that contain an email address.
The lens should be pretty sealed up. Use some compressed air, and a lens cleaner on the front of the unit, and see how that goes. If it needs further service of the lens you may need to bring it to a professional.
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Think you're probably referring to your automatic lens cover. If so,
this blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be somewhat similar for an A550. The exception being that the A550 has four shutter leaves instead of simply two as the A400 has. Highly recommend trying the non-obtruisive fixes first, and giving them a second try before going in there:
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
