Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
Anonymous Posted on Oct 10, 2011
Vertical lines running through video when I view it on the camera and on my computer.
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Oct 10, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14459458
Points
60858
Sound like a malfunctioning CCD-image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your technical service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Applied warranty, if underwarranty yet. Dont forgetted to ratings and leave an testimonial comment about this free answer.
Hope this helps.
1helpful
CANON E61 PLAYBACK
Have you tried using a different cable ? Is the camcorder set up to output to the TV ?
I dropped my Lumix DSC ZS3 and now there are
november 23 2010
i dropped my panasonic dmc-zs3 and now there are vertical lines on the view finder. also, these lines appear after taking a photo or video.
can this be repaired?
cost?
thank you in advance ;-(
1helpful
Lines run vertically through the screen but only onlive view
you mini lcd screen is having troubles.. it will soon out of use..contact a technician as this is a mechanical problem
Held my Pentax Optio S12 vertically when I shot a video
I used DVDVideoSoft Free Studio. It's a free program that rotated my video 90 degrees, and I can now view the video without laying on my side to view it properly ... LOL.
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
2answers
Multi-coloured vertical lines on LCD screen and view finder
Hello, there is a chance for the Sony recall. Please contact your nearest Authorized Sony Service. If you need more info please advice.
Unable to view or record video
i fear you have a bad CCD. replacement of the same may rectify the problem.
Reddish vertical lines on LCD & view finder
There is a CCD service advisory for the F717. They will repair it free of charge. Go here for more details: http://www.imaging-resource.com/badccds.html
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
