If you try to burn this on a single layer DVD disk then you will get this error message unless your DVD burn program can compress the video so it can fit on a single layer DVD disc. OTHERWISE You need to upgrade your burner to a dual layer burner and burn your video onto a dual layer DVD disc.
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
The model is DH-6100P, 80gb HDD crashed then formatted it. Now no start-up menu, stuck please help with solution or firmware file for re-install if possible.
yes there is .......u can reset to factory setting.....u will find it in ur Manuel booklet///// if not go in touch with daewoo service depaartment and u will get help from them cheers hope all works out for u.......
You might try turning the power off, then unplugging the unit. After approximately one minute, plug the unit back in. Wait five seconds, then press the power button. Wait two seconds, then press the open/close button slowly five times.
It is also a good idea to clean the front and back of your DVDs on a regular basis with alcohol. Wipe the DVDs side to side, not in a circular motion.
I checked in the instruction manual and found out that I had not "finalised: the DVDs that I had recorded. So I reckon that this will solve my problem.
Report your Video shop to RiSA. They should legally only carry zone 2 DVD's as a rental copy and a sale copy has two different licenses of use. If they have zone 1 DVD's it means they are bypassing the local supply chain (ie getting it outside South Africa) and damaging the industry as a whole.
