Dear Sir:
Thank you by your request, I will help you right now.
Please do this step with VERY CAREFULLY!!!.
A multimeter isa versatile tool for measuring voltage and current. Electricians usemultimeters to measure alternating current, or AC, and direct current, or DC,voltages and currents. Many multimeters also measure resistance, capacitanceand temperature. For example, an electrician uses the multimeter's AC voltagesetting to determine if a wall outlet has power or if a power supply isfunctioning. This knowledge helps the electrician pinpoint the cause of anelectrical problem and select the appropriate repair.
Difficulty:
Moderately EasyInstructions
1.
Plugthe black voltage probe into the voltmeter jack marked "COM."
Plugthe red voltage probe into the voltmeter jack marked "V."
Rotatethe range selector knob to the highest range setting, which is marked"VAC."
Turnthe voltmeter on. Slide the power switch to the "ON" position.
Touchthe probes to the device for which you measure the AC voltage. Use extremecaution. Ensure that the probes do not come into contact with anything but thesurface you are measuring.
Readthe voltmeter's display. Turn the range selector knob to a lower range ifvoltage is less than the currently selected range
Thank you in advance, sincerely. God bless you.
If you need further assistance, please contact me
E.CUADRA
MANAGUA, NICARAGUA.
Watch this videos tips: for motor
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
you must check the Transforme, i am giving tip for to do that.The transforme is for control for board of incline motor. See the fuse or breaker for incline motor board, or some wire loose.
See carefully the videos.
