Try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
If the drive can be seen by device managerbut not under My Computer, right click my computer and go to"Manage". (Check out:right clicking my computer icon on your desktop,select disk manager)
You should see your harddrive either lister as foreign or not initialized. Ifforeign, it will give you an option to import and is not initialized, it willallow you to initialize it.
This will hand over drive management to the OS and you should be able to see itin My Computer.
How about asking you to format it before you can use it?Then you can recover datafrom hard drive withdata recovery software like Tenorshare DataRecovery.It can recover data after deeply scanning your hard drive to look forlost data.You can get it from: http://www.any-data-recovery.com/index.htm
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
