You have to replace the seal O-Ring located in the sprung Rod. You can find the O-Ring in the following link. If you are not aware of oppening and replaceing the O-Ring then do it with some reparing shope near you.
http://www.chsinteractive.co.uk/manufacturer_replacement_parts/krups/EA8025/
Go to the link and click on the seal O-Ring On the Product box.
OK
Hi sveevens,
This leak issue is often caused by the boiler seal. The broiler gets clogged up with coffee oils then causes back pressure and blows the broiler seal out. The easiest way to correct this problem is to replace the seal.
Hope it helps.
Thank you for using FixYa.
Thank you.
How do I open the cofeemaker?
Wher do I Get a new seal?
Where is it?
How do I replase it?
Best Regards
Sven-Ole Evensen
Hi
Thank you.
Where do I Get a New seal?
Enere do I fond the seal?
how do I change It?
Best regards
Sven-Ole Evensen
