SOURCE: Sony Vaio not Booting
Have you tried booting with a windows cd, and then running a disk check?
SOURCE: Averatec 3200 Series Laptop
Sure you can just re-install XP, but you will loose all of your documents and programs.
That's simple and if you have not installed anything - you can go that way.
If you want to keep everything on your laptop, you just need to repair the existing Windows installation.
This is how you do it:
If the automatic repair doen't work, then you have to copy the file manually to your C: drive.
This way you keep whatever is on your computer and just replace the damaged file.
SOURCE: When I turn ny acer
check this link and try the solutions given in the threads
http://ubuntuforums.org/showthread.php?t=442945
SOURCE: Whe I boot my HP
Go for reset but your all data will be erase ,follow the step.
setting >security setting >
If problem is same .
Dissamble the phone and change the speaker ,with help of nearest technician.
http://www.formymobile.co.uk/6300disassembly.php
http://www.forum-gsmrepair.com/tips-tricks-mobilephone-repair/34220-6300-speaker-earpiece-ways-problem.html
Hope this helps.
SOURCE: I get the main acer screen but it wont boot. Just
You've got back lights problem. Please repair it at dealer
