Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
As you evaluate my advise. solutions and suggestions, there are a few things you must keep in mind:
• I did not diagnose your problem and am therefore only able to evaluate what you tell me. For example, if you ask me a fuse location, that doesn't mean that I can tell you the reason why the fuse blew. I can only react to the information that you provide. So please judge my suggestions accordingly.
• A thorough diagnostic approach involves the use of technical equipment, such as voltage meters. scanning equipment and other sophisticated devices. Diagnostic tools can be borrowed from AutoZone for FREE:
• Lastly, fixing one problem can very easily reveal a problem with something that you might consider unrelated. If that happens, you might want to view me as being incompetent.
Your description of the problem: car started and stalled, 3 times and then will not start at all. ?
possible security system but do not know how to reset at home, or do I
have it towed to a dodge dealership?
First: You don't indicate any diagnostic tests to date. A dealer or your local mechanic will charge $100-$200 to perform a diagnostic scan. However, AutoZone will provide a thorough scan for FREE or you can buy a code reader for about $30. Anyone who tells you that a modern vehicle can be diagnosed without a scanner with the problems you have set forth is merely guessing. You car has a computer and memory and probably knows exactly what the problem is. That on-board computer is just waiting for you to ask, "What's wrong".
However, if you believe that your problem is with the security system, read the following carefully.
Please don't even think about trying to disarm your anti-theft system because there is an easier solution. I'm assuming that you don't have the full Shop Service Manual. If you do, then you know that a shop manual costs at least $100.
So why did I say: Don't even think about it? Your anti-theft device is capable of causing problems that you don't want to deal with. If you have the dealer do the job, the cost can be prohibitive. The anti-theft device tells the on-board computer to shut off the fuel flow and to disengage the starter circuitry.
SOLUTION: Go on eBay and buy an anti-theft bypass module for $10-$20 depending on the year and make of your vehicle.
All the best
Ben
