Acer Extensa 4620 Notebook Logo
Posted on Sep 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop infected by W32/Blaster.worm - Acer Extensa 4620 Notebook
Curtis Sewell
Level 3:
  • Master 7,482 Answers
  • Posted on Sep 03, 2011
Curtis Sewell
Master
Level 3:
Answers
7482
Questions
Helped
1943190
Points
24946
Hi oteyolasamue...
To remove a virus,trojan,worm,etc from your computer...do it the EASY way...let someone else do it for you.
Start your computer, as the computer is starting keep tapping the F8 Key.
This will start the computer in the Safe Mode.
Once in the safe mode go to the following webage below and download,install, and run Microsoft Safety Scanner for FREE.
Once you run the Microsoft Safety Scanner (it may take quite a while depending on the size of your hard drive) it will remove all the virus's,trojans,worms,etc it finds, if it does not completely remove them all you will be given a chance to chat with a Microsoft Professional thru a pop open window and he will take control of your computer (with your permission) and finish removing all the rest of the virus's, trojans, or worms that are on your computer for FREE!! Can't beat FREE!!
You have a virus,worm,trojan,etc on your computer.
Go to the following website and download,install and run the FREE Microsoft Safety Scanner.
Please take time to rate me
http://www.microsoft.com/security/scanner/en-ca/default.aspx
1 Related Answer
Anonymous
  • 68 Answers
SOURCE: Acer PC infected by W32/Blaster worm
I think that Quick Heal Anti Virus can clean this problem completely for Quick Heal Full Version go to http://www.xviruslab.com
and find the blog index than click on Quick Heal 2011 than you can find the Quick Heal Internet Security, Quick Heal Total Security 2011 and Quick Heal Anti Virus for Server Edition 2011 download as per your requirement.
Thank you
Keerthyinfo
2answers
W32.Blaster.Worm. how do i get rid of it
this tells you how to remove it
http://www.symantec.com/security_response/writeup.jsp?docid=2003-081119-5051-99
1helpful
W32/blaster worm, how to unlock frozen screen
repeatedly press f8 after youve pushed the power button. this will start your pc in safe mode. click the start menu and in the run box type ( msconfig ) only using the letters m,s,c,o,n,f,i,g. then select the startup tab located at the top center of the popup screen. you will then see a list of items with a check mark located next to each of them or just some of them. unchech each one and then hit apply. you will then be prompted to restart your system. let it startup normally. you will get a prompt telling you your system has been changed to a selective startup. just check the box and choose it not to prompt you again. this should allow you to boot up and use your anti virus program to remove the virus threat.
you will no longer see some of the icons in the lower right hand corner of your screen as a result of unchecking those items, but they will still function properly without any issues.
below , i have included a link that will provide you with a w32/blaster worm removal tool. download the program to your desktopp the doublle click the icon to run the tool. this wiull be extremely helpfull if your AV software is out of date or already corrupted by the worm itself. a blaster worm has the potential to completely disable your current AV program, so id for sure try it first as a definate removal result.
if you need any further assistance in helping you with this , please feel free to contact me via [email protected]
http://download.cnet.com/W32-Blaster-Worm-Removal-Tool/3000-2092_4-10219756.html
How can i remove w32 blaster worm
If there is w32 blaster worm on your computer, it seems there is not only this worm but also other problems. You can use some anti-virus software such as Kaspersky or Norton to remove the w32 blaster worm. If it doesn't work, reinstall operating system. If you are in emergency and not a computer expert, I suggest you do this by some software. Some software can check your computer health first and report your computer status including software, hardware, security and stability. Then you may follow simple steps to remove all viruses and fix other hidden errors.
2helpful
4answers
Cannot access anti-virus websites
Download STINGER antivirus and scan with this tool.
Variants Can Detect:
BackDoor-ALI,BackDoor-AQJ,BackDoor-AQJ.b,BackDoor-CEB,BackDoor-CEB!bat,BackDoor-CEB!hosts,BackDoor-CEB.b,BackDoor-CEB.c,BackDoor-CEB.d,BackDoor-CEB.dll,BackDoor-CEB.dr,BackDoor-CEB.e,BackDoor-CEB.f,BackDoor-CEB.sys,BackDoor-CFB,BackDoor-JZ,BackDoor-JZ.dam,BackDoor-JZ.dr,BackDoor-JZ.gen,BackDoor-JZ.gen.b,Bat/Mumu.worm,Cleanup,CoreFlood,Coreflood!psexec,Coreflood.dldr,CoreFlood.dll,CoreFlood.dr,Danmec,Downloader-DN.a,Downloader-DN.b,Downloader-UA,Exploit-DcomRpc,Exploit-DcomRpc.b,Exploit-DcomRpc.dll,Exploit-Lsass,Exploit-Lsass.dll,Exploit-MS04-011,Exploit-MS04-011.gen,Exploit-MSExcel.k,Exploit-MSExcel.l,Exploit-MSExcel.m,Exploit-MSExcel.n,Exploit-MSExcel.o,Exploit-MSExcel.p,Exploit-MSExcel.q,Exploit-MSExcel.r,Exploit-PDF.b,Exploit-PDF.c,Exploit-PDF.d,Exploit-PDF.e,Exploit-PDF.f,Exploit-PDF.g,Exploit-PDF.h,Exploit-XMLhttp.d,Exploit-XMLhttp.d.gen,Exploit-XMLhttp.d.gen.b,Exploit-XMLhttpd.d,FakeAlert,FakeAlert-AA,FakeAlert-AB,FakeAlert-AB!htm,FakeAlert-AB.dldr,FakeAlert-AB.dr,FakeAlert-AC,FakeAlert-AD,FakeAlert-AE,FakeAlert-AF,FakeAlert-AG,FakeAlert-AG.gen.b,FakeAlert-AG.gen.c,FakeAlert-AH,FakeAlert-AI,FakeAlert-AJ,FakeAlert-AK,FakeAlert-AL,FakeAlert-AM,FakeAlert-AN,FakeAlert-AntiVirusPro,FakeAlert-AntiVirusXP,FakeAlert-AO,FakeAlert-AP,FakeAlert-AQ,FakeAlert-AR,FakeAlert-AS,FakeAlert-AT,FakeAlert-AU,FakeAlert-av360,FakeAlert-AW,FakeAlert-AZ,FakeAlert-AZ!htm,FakeAlert-B,FakeAlert-B.dldr,FakeAlert-B.dr,FakeAlert-BA,FakeAlert-BB,FakeAlert-BC,FakeAlert-BD,FakeAlert-BE,FakeAlert-BE.gen,FakeAlert-BF,FakeAlert-BG.dldr,FakeAlert-BH.dldr,FakeAlert-BI,FakeAlert-BJ,FakeAlert-BK,FakeAlert-BL,FakeAlert-BM,FakeAlert-BN,FakeAlert-BO,FakeAlert-BO.dldr,FakeAlert-BP,FakeAlert-BQ,FakeAlert-BR,FakeAlert-BS,FakeAlert-C,FakeAlert-C.dr,FakeAlert-C.gen,FakeAlert-D,FakeAlert-E,FakeAlert-F,FakeAlert-G,FakeAlert-H,FakeAlert-I,FakeAlert-J,FakeAlert-K,FakeAlert-L,FakeAlert-LastDefender,FakeAlert-M,FakeAlert-N,FakeAlert-N.dldr,FakeAlert-O,FakeAlert-P,FakeAlert-Q,FakeAlert-R,FakeAlert-S,FakeAlert-S.dll,FakeAlert-SpyKiller,FakeAlert-SpywareGuard,FakeAlert-T,FakeAlert-U,FakeAlert-V,FakeAlert-W,FakeAlert-WinwebSecurity,FakeAlert-X,FakeAlert-XPAntivirus,FakeAlert-XPSecCenter,FakeAlert-Y,FakeAlert-Y.dr,FakeAlert-Z,Fribet,Generic FakeAlert,Generic FakeAlert.d,Generic FakeAlert.e,Generic!atr,HideWindow,HideWindow.dll,HTool-T2W,IPCScan,IRC/Flood.ap,IRC/Flood.ap.bat,IRC/Flood.ap.dr,IRC/Flood.bi,IRC/Flood.bi.dr,IRC/Flood.cd,JS/Autorun.worm.ci,JS/Downloader-AUE,JS/FakeAlert,JS/FakeAlert-AB.dldr,NTServiceLoader,ProcKill,Proxy-Agent.af,Proxy-Agent.af.dr,PWS-Banker.dldr,PWS-FireMing,PWS-FireMing.dll,PWS-FireMing.dr,PWS-Gamania.gen.a,PWS-Narod,PWS-Narod.dll,PWS-Narod.gen,PWS-Sincom,PWS-Sincom.dll,PWS-Sincom.dr,rootkit,VBS/Autorun.bj,VBS/Autorun.worm.au,VBS/Autorun.worm.ay,VBS/Autorun.worm.bi,VBS/Autorun.worm.bj,VBS/Autorun.worm.bs,VBS/Autorun.worm.by,VBS/Autorun.worm.ca,VBS/Autorun.worm.cy,VBS/Autorun.worm.dm,VBS/Autorun.worm.dn,VBS/Autorun.worm.dn!atr,VBS/Autorun.worm.dn!txt,VBS/Autorun.worm.dv,VBS/Autorun.worm.dz,VBS/Autorun.worm.en,VBS/Autorun.worm.k,VBS/Autorun.worm.k!bat,VBS/Autorun.worm.zd,VBS/Autorun.worm.ze,VBS/Autorun.worm.zl,VBS/Autorun.worm.zn,VBS/FakeAlert-AB,VBS/IE-Title,Vundo,Vundo.dldr,Vundo.dr,Vundo.gen.h,Vundo.gen.i,Vundo.gen.j,Vundo.gen.k,Vundo.gen.l,Vundo.gen.m,Vundo.gen.n,Vundo.gen.o,Vundo.gen.p,Vundo.gen.r,Vundo.gen.s,Vundo.gen.t,Vundo.gen.u,W32/Anig.worm,W32/Anig.worm.dll,W32/Autorun.worm,W32/Autorun.worm!inf,W32/Autorun.worm!ini,W32/Autorun.worm.a,W32/Autorun.worm.aa,W32/Autorun.worm.ab,w32/autorun.worm.ac,W32/Autorun.worm.ad,W32/Autorun.worm.ae,W32/Autorun.worm.af,W32/Autorun.worm.ag,W32/Autorun.worm.ai,W32/Autorun.worm.aj,W32/Autorun.worm.ak,W32/Autorun.worm.al,W32/Autorun.worm.am,W32/Autorun.worm.an,W32/Autorun.worm.ao,W32/Autorun.worm.ap,W32/Autorun.worm.aq,W32/Autorun.worm.ar,W32/Autorun.worm.as,W32/Autorun.worm.at,W32/Autorun.worm.av,W32/Autorun.worm.aw,W32/Autorun.worm.ax,W32/Autorun.worm.az,W32/Autorun.worm.b,W32/Autorun.worm.b.cfg,W32/Autorun.worm.ba,W32/Autorun.worm.bb,W32/Autorun.worm.bc,W32/Autorun.worm.bd,W32/Autorun.worm.be,W32/Autorun.worm.bf,W32/Autorun.worm.bg,W32/Autorun.worm.bh,W32/Autorun.worm.bk,W32/Autorun.worm.bl,W32/Autorun.worm.bm,W32/Autorun.worm.bn,W32/Autorun.worm.bo,W32/Autorun.worm.bp,W32/Autorun.worm.bp!reg,W32/Autorun.worm.bq,W32/Autorun.worm.br,W32/Autorun.worm.bt,W32/Autorun.worm.bw,W32/Autorun.worm.bx,W32/Autorun.worm.bx!inf,W32/Autorun.worm.bx.gen,W32/Autorun.worm.bz,W32/Autorun.worm.c,W32/Autorun.worm.cb,W32/Autorun.worm.cb.dr,W32/Autorun.worm.cc,W32/Autorun.worm.cd,W32/Autorun.worm.ce,W32/Autorun.worm.cf,W32/Autorun.worm.cg,W32/Autorun.worm.ch,W32/Autorun.worm.cj,W32/Autorun.worm.ck,W32/Autorun.worm.cm,W32/Autorun.worm.cn,W32/Autorun.worm.co,W32/Autorun.worm.cp,W32/Autorun.worm.cp!bat,W32/Autorun.worm.cq,W32/Autorun.worm.cr,W32/Autorun.worm.cs,W32/Autorun.worm.ct,W32/Autorun.worm.cu,W32/Autorun.worm.cv,W32/Autorun.worm.cw,W32/Autorun.worm.cx,W32/Autorun.worm.cz,W32/Autorun.worm.d,W32/Autorun.worm.da,W32/Autorun.worm.db,W32/Autorun.worm.dc,W32/Autorun.worm.dd,W32/Autorun.worm.dd!inf,W32/Autorun.worm.de,W32/Autorun.worm.df,W32/Autorun.worm.dg,W32/Autorun.worm.dh,W32/Autorun.worm.di,W32/Autorun.worm.dj,W32/Autorun.worm.dk,W32/Autorun.worm.dl,W32/Autorun.worm.dn,W32/Autorun.worm.do,W32/Autorun.worm.dp,W32/Autorun.worm.dq,W32/Autorun.worm.ds,W32/Autorun.worm.dt,W32/Autorun.worm.du,W32/Autorun.worm.dw,W32/Autorun.worm.dx,W32/Autorun.worm.dy,W32/Autorun.worm.e,W32/Autorun.worm.ea,W32/Autorun.worm.eb,W32/Autorun.worm.ec,W32/Autorun.worm.ed,W32/Autorun.worm.ef,W32/Autorun.worm.eg,W32/Autorun.worm.ei,W32/Autorun.worm.ej,W32/Autorun.worm.ek,W32/Autorun.worm.el,W32/Autorun.worm.em,W32/Autorun.worm.eo,W32/Autorun.worm.ep,W32/Autorun.worm.eq,W32/Autorun.worm.f,W32/Autorun.worm.g,W32/Autorun.worm.gen!job,W32/Autorun.worm.gen.cl,W32/Autorun.worm.gen.za,W32/Autorun.worm.gen.zb,W32/Autorun.worm.h,W32/Autorun.worm.h!lnk,W32/Autorun.worm.i,W32/Autorun.worm.j,W32/Autorun.worm.l,W32/Autorun.worm.m,W32/Autorun.worm.n,W32/Autorun.worm.o,W32/Autorun.worm.p,W32/Autorun.worm.q,W32/Autorun.worm.r,W32/Autorun.worm.remmants,W32/Autorun.worm.s,W32/Autorun.worm.t,W32/Autorun.worm.u,W32/Autorun.worm.v,W32/Autorun.worm.v!bat,W32/Autorun.worm.w,W32/Autorun.worm.x,W32/Autorun.worm.y,W32/Autorun.worm.z,W32/Autorun.worm.zc,W32/Autorun.worm.zf,W32/Autorun.worm.zg,W32/Autorun.worm.zh,W32/Autorun.worm.zi,W32/Autorun.worm.zj,W32/Autorun.worm.zk,W32/Autorun.worm.zm,W32/Bagle,W32/Bagle!eml.gen,W32/Bagle!pwdzip,W32/Bagle.ad!src,W32/Bagle.dldr,W32/Bagle.dll.dr,W32/Bagle.eml,W32/Bagle.fb!pwdzip,W32/Bagle.fc!pwdzip,W32/Bagle.fd!pwdzip,W32/Bagle.fe!pwdzip,W32/Bagle.fm.dldr,W32/Bagle.gen,W32/Bagle@MM!cpl,W32/Blaster.worm,W32/Blaster.worm.k,W32/Bropia.worm,W32/Bugbear,W32/Bugbear.a.dam,W32/Bugbear.b!data,W32/Bugbear.b.dam,W32/Bugbear.gen@MM,W32/Bugbear.h@MM,W32/Bugbear@MM,W32/Conficker,W32/Conficker.sys,W32/Conficker.worm,W32/Conficker.worm!inf,W32/Conficker.worm!job,W32/Conficker.worm.gen.a,W32/Conficker.worm.gen.b,W32/Deborm.worm.ah,W32/Deborm.worm.gen,W32/Doomjuice.worm,W32/Dumaru,W32/Dumaru.ad@MM,W32/Dumaru.al.dll,W32/Dumaru.dll,W32/Dumaru.eml,W32/Dumaru.gen,W32/Dumaru.gen@MM,W32/Dumaru.w.gen,W32/Elkern.cav,W32/Elkern.cav.c,W32/Elkern.cav.c.dam,W32/Fizzer,W32/Fizzer.dll,W32/Fujacks!htm,W32/FunLove,W32/FunLove.apd,W32/Gaobot.worm,W32/Harwig.worm,W32/IRCbot,W32/IRCbot.worm,W32/IRCbot.worm.dll,W32/Klez,W32/Klez.dam,W32/Klez.eml,W32/Klez.gen.b@MM,W32/Klez.rar,W32/Koobface.worm,W32/Korgo.worm,W32/Lirva,W32/Lirva.c.htm,W32/Lirva.eml,W32/Lirva.gen@MM,W32/Lirva.htm,W32/Lirva.txt,W32/Lovgate,W32/Mimail,W32/Mimail.c@MM,W32/Mimail.i!data,W32/Mimail.q@MM,W32/MoFei.worm,W32/MoFei.worm.dr,W32/Mumu.b.worm,W32/Mydoom,W32/Mydoom!bat,W32/Mydoom!ftp,W32/Mydoom.b!hosts,W32/Mydoom.dam,W32/Mydoom.t.dll,W32/Mytob,W32/Mytob.gen@MM,W32/Mytob.worm,W32/MyWife,W32/MyWife.dll,W32/MyWife@MM,W32/Nachi!tftpd,W32/Nachi.worm,W32/Netsky,W32/Netsky.af@MM,W32/Nimda,W32/Nimda.dam,W32/Nimda.eml,W32/Nimda.gen@MM,W32/Nimda.htm,W32/Nuwar,W32/Nuwar.dam,W32/Nuwar.sys,W32/Nuwar@MM,W32/Nuwar@MM!rar,W32/Pate,W32/Pate!dam,W32/Pate.dam,W32/Pate.dr,W32/Polip,W32/Polip!mem,W32/Polybot,W32/Polybot.bat,W32/Sasser.worm,W32/Sasser.worm!ftp,W32/Sdbot,W32/Sdbot!irc,W32/Sdbot.bat,W32/Sdbot.cli,W32/Sdbot.dll,W32/Sdbot.dr,W32/Sdbot.worm,W32/Sdbot.worm!ftp,W32/Sdbot.worm.bat.b,W32/Sdbot.worm.dr,W32/Sdbot.worm.gen,W32/Sdbot.worm.gen.a,W32/Sdbot.worm.gen.b,W32/Sdbot.worm.gen.c,W32/Sdbot.worm.gen.d,W32/Sdbot.worm.gen.e,W32/Sdbot.worm.gen.q,W32/Sober,W32/Sober!data,W32/Sober.dam,W32/Sober.eml,W32/Sober.f.dam,W32/Sober.g.dam,W32/Sober.q!spam,W32/Sober.r.dr,W32/Sober.r@MM,W32/Sobig,W32/Sobig.dam,W32/Sobig.eml,W32/Sobig.f.dam,W32/Sobig.gen@MM,W32/Spybot.worm,W32/SQLSlammer.worm,W32/Swen,W32/Swen@MM,W32/Virut,W32/Virut!mem,W32/Yaha.eml,W32/Yaha.gen@MM,W32/Yaha.y@MM,W32/Yaha@MM,W32/Zafi,W32/Zafi.b.dam,W32/Zindos.worm,W32/Zotob.worm,W32/Zotob.worm!hosts
Download v10.0.0.482 [2,641,920 bytes] (01/10/2009).
Hope this will be helpfull
Thanks & Regards
Nanda Kishore :)
2answers
Funny UST Scandal
hi my friend got that last week to... ehat you need to do is download kaspersky. after running kaspersky. that will be gone. you can download kaspersky @ majorgeeks.com Here are some examples of autorun viruses which rely on the autorun function of Windows to infect PC’s and flash drives. Funny UST Scandal.avi.exe Autorun.vbs win32.autorun.k copy.exe imgkulot taga lipa are autorun.vbs recycler FS6519.dll.vbs strawberry from baguio W32/Perlovga (copy.exe | host.exe) VBS_RESULOWS.A Bha.dll.vbs w32automa worm (Autorun.vbs) Trojan.Win32.VB.atg | Win32/Dzan | Worm_vb.bnr (tel.xls.exe | mmc.exe) W32/RJump.worm (RavMonE) Worm.Win32.Delf.bf | W32.Fujacks (spoclsv.exe) W32.Fujacks.BH (****.vbs) WORM_AGENT.PGV (soundmix.exe) W32/Hakaglan.worm (RVHost.exe) Trojan.Win32.VB.ayo [AVP] (Macromedia_Setup.exe) Trojan.VBS.DeltreeY.b#1 (Destrukto!!! | destrukto.vbs) if you want to manually delete it... Solution is here: 1. Start Notepad [Start Menu-All Programs-Accessories-Notepad] or right-click any empty space in your desktop then select New-Text Document 2. Copy the following text. (note: Everything in between the square brackets should be in one line) REGEDIT4 [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionIniFileMappingAutorun.inf] @="@SYS:DoesNotExist" 3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part) 4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear. hope this helps
Automaticly restarting, shooting down
first try a reset in your router settings, by typing 192.168.0.1 in your web browser, and you also may have to try a firmware update, but you need to find the version of your router underneath, so refer to this page and see if you have the current firmware:- http://support.dlink.com/products/revision.asp Please be aware that any firmware upgrades need to be done with the rj45 cable and not wirelessly Otherwise, if it's rebooting it could be the W32.Blaster Worm, many other variations of this worm have been found. Some of them are W32/Lovsan.worm and W32/Nachi.worm. These worms create a lot of ICMP traffic which may overload the router to eventually prevent it from communicating. Whether it´s the CPU or another component of the router that causes the failure, the problem can only be solved through the removal of this virus. There´s a tool provided by McAfee called Stinger. This tool will detect and remove the viruses that cause these problems. Please take a minute to read about this tools and it´s usage. You will need to run this tool on every single computer. the tool can be found here:- http://vil.nai.com/vil/stinger/
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
