On farmville i unlocked the english countryside when the pilot showed up and it showed me the globe i kept clicking on it but but my english farm wouldnt pop up so i refreshed the page and now the pilot won't pop up anymore what do i do
Easiest way to contact Zynga support is via https://www.zyngaplayersupport.com/ click your game; then on right hand side there's a red "?Get Help" click on this then either mail them or use chat.
Have you tried switching which farm you're on? You can travel between several farms and usually the new one becomes the default for some people. In the top right corner there should be a spot that says Haunter Hollow that has a message sign on the left of it and a globe on the right. If you click this it should let you switch between farm worlds. Otherwise at the bottom of the farm screen there's a spot that says support they might be able to help you more. As far as it not letting you visit other people report the problem to zynga they have had several errors lately they're tryng to get fixed
Its that your farm is not connecting with the farmville server. Mostly it is due to the enhancements made by the farmville on a weekly basis. This is a common intermittent problem occur across the globe. It will get fixed by itself in a day or two. If you want a immediate and temporary solution I would recommend you to restart the router. It may or may not fix the problem. Revert to me if your problem is fixed.
Most likely you accidently blocked the Farmville application. To check if it's blocked, click your account settings in the upper right corner. Then go to Privacy Settings, and choose Applications and Websites. From there open the list of Blocked Applications. If Farmville is there, click remove and the block will be lifted and you will be farming once again.
Try cleaning your temperary Internet files. Click on tools and click on options. On that there should a delete button, and let it delete what is checked. That should do it.
