Samsung Laptop / Intel Core i5 Processor / 14" Display / 4GB Memory - Aluminum (QX410J01) PC Notebook Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't run games fast because i have the intel core i3, which i have been tierd searching for a free download for intel core i5. can you please give me a link for free download?
Robbie
Level 2:
New Friend:
  • Expert 35 Answers
  • Posted on Aug 25, 2011
Robbie
Expert
Level 2:
New Friend:
Answers
35
Questions
0
Helped
11478
Points
100
The Intel core i5 is a physical object, so unfortunately there are no downloads for one. Hope this helps.
About Intel Processors
Core i7 is the best, then downwards its the Core i5, then the i3
1helpful
Samsung r480
Your Motherboard is a BA92-06357A Socket 939? Here are the Specs for the i3-330m: http://www.notebookcheck.net/Intel-Core-i3-330M-Notebook-Processor.23753.0.html Take a look at these, they appear to be compatible, do all your research to verify, the devil is in the detail, power consumption is 35watts: http://www.cpu-world.com/Compare/724/Intel_Core_i3_Mobile_i3-330M_(PGA988)_vs_Intel_Core_i5_Mobile_i5-430M_(PGA988).html Your increase in performance will be minimal Have you ever install a CPU in a Laptop? Here is a little freeware program that will help you ID your hardware, SPECCY: http://www.filehippo.com/search?q=speccy You could add up to 8GB of memory and a 7200rpm HDD? Keep in mind, upgrades sometimes require more power, more power, more heat. New fan. etc., etc.
What is deffrence between core i3, and core i5
There's two main differences between them that i can think off the top of my head.
1) The speed at which the processor works (where i5 works faster than i3)2) The number of cores it has.
Cores are like little computers inside the computer itself. The i3 has 2, while the i5 usually has 4. usually the more cores a computer has the better it is at doing background processes.
Which is better, amd quad core or intel i3?
Don't ever doubt the answer. I suggest, go for AMD. If you are considering other Intel processors, I will say that i5 and i7 are both better than AMD quad core.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Regards,
Sunny.
2answers
Can I upgrade video card of asus k42f?
Your laptop graphics card can't be upgrade.It is integrated on your laptop's motherboard.
How can i use oracle in win 7 platform of i3 processor?and which processor is best core 2 duo or core i3?
Windows 7 Release Candidate was publically released on May 5, 2009. This should be the final release before it goes live later this year. download it, install it in a VM inside of VirtualBox and try to install Oracle on it. There is no Oracle release for Windows 7, so instead grab the Windows 2008 one. The install is pretty straight forward. The only "gotcha" is that if you go to the command prompt, you need to run it as the Administrator, so that all of the Oracle commands will work (lsnrctl, dbca, netca etc...) Really there is not that much to it as it was pretty seemless. So, if you download Windows 7, then you can also download Oracle 11g and start playing with it today!
Here is the second answer
We live in the times where computing power, once available only at the level of super computers, has been made available to the common man. The forerunner in the race, who's probably miles ahead of its competitors is the computing giant Intel. According to the needs of computer users, Intel delivers chips with varying degrees of power and clocking speed. These include the entry level, mid level and high end processors. The latest entry level Intel chips to hit the market are the core i3 processors which are aimed at taking up the place previously held by the core 2 duo processors. The new hierarchy of Intel chips in ascending order of computing power are the core i3, core i5 and core i7 processors. Although core 2 duo processors are slowly being phased out of production, they are still available in the market. In this article, I present a core i3 vs core 2 duo review which may help you decide which one to go for.
Intel Core i3 Vs Core 2 Duo Comparison
A comparison between processors was simple some years ago with a single core processor. All you had to look at was the clocking frequency and the cache size. The entry of multiple core chips changed it all and life became complicated. With dual, quad and even six core processors hitting the market, there are many more factors to be considered than before. Intel's dual core and core 2 duo processors were the first ones to introduce the multicore processor computing power. The quad processors created later have given rise to the quad core vs dual core debate, as well as the core i5 vs core i7 comparison which is something that high end computing market consumers should think about. Prior to that, we only had the 32 bit vs 64 bit processors comparison.
Today, Intel has gone through a lot of designing and planning to introduce core i3 processors that are an improvement over the core 2 duo processors. The following Intel core i3 vs core 2 duo processor comparison will give you an idea about how the i3 processors are different from their dual core predecessors. The two points of comparison will be technical specifications and the only other factor which matters that is performance.
Core i3 Vs Core 2 Duo: Technical Specifications
Like the core 2 duo processors, the new core i3 line of processors, have two cores with many other technological enhancements including an integrated GPU (Graphic Processing Unit). The clocking frequency of the core i3 series of processors ranges from 2.26 GHz to 3.06 GHz. Each processor is endowed with the new line of advanced technologies including Intel developed hyperthreading, Intel virtualization and smart cache technology which makes these chips faster than core 2 duo processors. This is the most important point in the core i3 vs core 2 duo comparison.
The Intel codename for core i3 architecture is Clarkdale. They are based on the Westmere architecture with 32 nm fabrication and a direct media interface (DMI) bus. The socket type used for core i3 processors is LGA 1156 and the RAM type is DDR3. They support mother boards with the following types of chipsets- H55, P55, H57 and Q57.
Let us have a look at the latter processors in the core i3 vs core 2 duo comparison. Core 2 Duo processors come in three types of architectures, codenamed as Conroe, Wolfdale and Allendale. With 65 nm and 45 nm fabrications they are a tad slower and less power efficient than the 32 nm based core i3 processors. The socket used for core 2 duo processors is LGA 775 and they come with a FSB bus. The FSB bus is a lot slower in operation than the DMI bus in core i3 processors.
Coupled with the fact that the i3 processors have a L2 cache size of 2 x 256 kb and a L3 cache size of 4MB, with hyperthreading and smart cache enabled, core 2 duo processors are indeed slower. On top of that, DDR3 RAM compatibility in core i3 processors, compared to DDR2 compatibility of core 2 duo processors makes them even more faster. The price range of Intel core i3 is $100 to $133, which makes them top options in the entry level market.
Core i3 Vs Core 2 Duo: Performance
The technical specifications have made it clearly indicated that Intel core i3 beats its predecessor, core 2 duo in almost all departments. This is but natural as they were indeed designed to replace them. Be it processing speed, multitasking or graphic output, opting for core i3 processors is the logical choice to make!
Hope the core i3 vs core 2 duo processor comparison provided in this article has made it easier for you to choose the right processor for your personal desktop computer or laptop computer. Going for a more advanced line of processors is always beneficial in the long run. You should also check out the Intel core i5 and core i7 processors before going ahead as they offer far more computing power and speed, compared to the entry level core i3 or core 2 duo. Decide on the processor you want according to your usage requirements and of course giving due thought to your vitamin 'M' levels!
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
I have an MSI motherboard i.e. baseboard 1.0 and i have an AMD athlon 2x 64 processes and i want to upgrade to an i3 or if possible an i5 processes will i be abel to do it and if so will it be i3 or i5...
Based on the model of your motherboard, it supports only Intel processors and not AMD. You can buy eitther i3 / i5 or i7 for a 1156 motherboard just like the one you have. Please see this link for the list of supported CPUs or processors : http://www.msi.com/index.php?func=prodcpu2&prod_no=1956&maincat_no=1
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
