20 Most Recent Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Questions & Answers
2answers
Digital Photo enhancers
What do you mean by "Digital Enhancer"? Do you mean like, taking a picture of a huge crowd with the faces little and tiny, then using a software program to make a really high-quality zoom-in of everybody's face? If you do, sorry to be the one to break it to you, but this is something you will only see in the movies.
1/5/2024 3:37:20 AM • Intel... • Answered on Jan 05, 2024
Pc shuts off after 30 to 40 minutes
The only reason a computer shuts of on its own generally is because the cpu in the motherboard has produced a heat sufficient to take the motherboard and itself to the shut off temperature set in the bios. The bios is the control software of the computer. If you have the assistance of a computer savvy individual you can ask them to check your shutdown temperature, whatever it is is causing problems. If the problem has only recently serfaced you need to check the effectiveness of your cooling. It may be that your fan has collected a lot of dust that has clogged the cooling fan up and has, consequently, reduced it's efficiency and leading to raised temperatures within the PC case. A clean up of the fan and heatsink could remedy this. It may be that the heatsink paste between the heatsink and the cpu is contaminated by dust, a fresh application of thermal paste might remedy this. The The fan ight be ageing and need renewing, this might cure the problem....the interior of the [C case should be cleaned/vacuumed out too. The issue is almost certainly heat associated, do not attempt to remedy just by increasing the shutdown temperature, this could lead to the expiry of your computer in the long run GOOD LUCK
7/3/2015 2:28:04 AM • Intel... • Answered on Jul 03, 2015
1801 microcode update Error missing
Check the Hewlett Packard website for a BIOS flash update.
5/26/2015 9:34:34 PM • Intel... • Answered on May 26, 2015
Cd/dvd will not read the a cd after the first
may be you copy the files to a DVD writer its shows the links in it.
3/24/2015 2:09:42 PM • Intel... • Answered on Mar 24, 2015
Mass storage controller driver for Windows 7
Use Windows update to install an approriate driver, or go to your motherboard's website (or computer's brand name website) . Locate "Support" and then "Download drivers".
12/16/2014 3:16:10 AM • Intel... • Answered on Dec 16, 2014
How to release a disc from laptop button stuck
Most cd or dvd in computewrs have a small hole them in the door. You will need a paperclip. Straighten it out insert the paerclip into the hole and push gently but firmly. This will open the door up and allow you to retrieve the disk
8/19/2014 4:49:08 AM • Intel... • Answered on Aug 19, 2014
7answers
Loss computer password
Hi.
I will try to help you.
If you mean a Windows Password, for me is imposible to help.
if the password is in the setup, you just have to remove the battery mounted in the mainboard and install it again after few seconds.( with the computer turned off)
Turn your computer on and there is no more password.
I hope this could help.
8/15/2014 9:25:17 AM • Intel... • Answered on Aug 15, 2014
How to download software & driver for MS-7222 VER:1.0
Are you sure that's the model #? Is that an MSI board? I found this link: MSI USA PM8PM Wasatch Techies Smartphone Tablet and Computer Repair in Utah
3/1/2014 5:32:55 PM • Intel... • Answered on Mar 01, 2014
2answers
Recover files back
If you formatted a drive there is no way to recover the deleted files. You can only recover a file of they were simply deleted, not formated.
1/11/2014 5:28:04 AM • Intel... • Answered on Jan 11, 2014
2answers
I have a Dual Core 32-bit processor on my eMachine D725 notebook and I bought a Windows 8 64-bit single language OS installation CD. Can I install it on my notebook?
Usually a 64bit Quad or Dual Core will work with 7/8. If you get Windows 8.1 Version, it will work as a general rule.
1/7/2014 6:03:15 PM • Intel... • Answered on Jan 07, 2014
Forgot administrator password for windows xp 5.1.2600
For XP administrator password recovery, I have used Windows Password Recovery Tool Ultimate to help me remove password and login my Dell XP laptop again in 5 minutes!
11/21/2013 2:36:59 AM • Intel... • Answered on Nov 21, 2013
Windows c is missing
You must have downloaded a virus or malware. Install Microsoft Security Essentials and Malwarebytes and run scans.
10/30/2013 4:51:32 AM • Intel... • Answered on Oct 30, 2013
Motorcraft alternator to regulator
Here is a generic wiring diagram that should work
10/27/2013 12:03:18 AM • Intel... • Answered on Oct 27, 2013
No sound card for amd sempron B105
update driver from manufacturer or from device manager.
10/21/2013 12:47:59 PM • Intel... • Answered on Oct 21, 2013
2answers
Error in os installation
change your XP cd and try again.
10/21/2013 12:40:28 PM • Intel... • Answered on Oct 21, 2013
When my pc pentiyum4 is then write on them''window
Most likely a hard drive problem check the drive and see.
9/9/2013 11:03:38 AM • Intel... • Answered on Sep 09, 2013
My internet explorer has stopped working
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html
4/6/2013 10:30:48 PM • Intel... • Answered on Apr 06, 2013
What is deffrence between core i3, and core i5
There's two main differences between them that i can think off the top of my head. 1) The speed at which the processor works (where i5 works faster than i3)2) The number of cores it has. Cores are like little computers inside the computer itself. The i3 has 2, while the i5 usually has 4. usually the more cores a computer has the better it is at doing background processes.
4/5/2013 10:26:15 PM • Intel... • Answered on Apr 05, 2013
2answers
I have a Pentium 4, 3.00Ghz 3.01 Ghz desktop and wish to upgade its am memo fom 500 mb to 4 gb or even 8gb. Is this possible? and what memo should I look for on ebay ?
You need to find the motherboard manual with all the specifications into find out what type to use.Also note: There's no point putting more than 4 gig in if you only have Windows 32 bit.
12/18/2012 6:39:55 PM • Intel... • Answered on Dec 18, 2012
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
246 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
dual core 32 bit processor emachine d725
  • Computers & Internet
