SOURCE: import excel sheet in vb.net 5
you have to make link in you vb then you can save the xls files on same format
SOURCE: duplicacy in excel sheet
Use COUNTIF formulae to found duplicate records in the excel spreadsheet.
SOURCE: Forgot password to open Excel sheet
If you mean that you can open the Workbook and read the Worksheet - then all you have to do is select all and paste it to another Worksheet. This will allow for changes of formulas etc.
If you mean the whole Workbook - then I dunno.
In future, either use the same password for everything (easy to remember) or Protect the work with nothing entered into the password field (leave this blank). This last will protect the work from people who try to guess your password, but will be easy for you to remember - eg every password is left blank.
If you must use unique passwords, then keep a record of them somewhere other than on your computer.
Sorry I can't help with the "Workbook" solution - but somebody else out ther may be able to do so.
SOURCE: data sorting in Excel
If the serial numbers of all the names on the column are A1-A100.
and you want to count the no of people with a name that appears on A6.
use this
=COUNTIF(A1:A100,A6)
function go(url)
window.open(AppendFromParamToUrl(url), "_self");
function OpenInNewWindow(url)
window.open(AppendFromParamToUrl(url), "_blank");
function AppendFromParamToUrl(url)
if (null != url)
url += (url.indexOf("?") > -1) ? "&from=" : "?from=";
url += escape(window.location.href);
return url;
var L_UNDEFINED_TEXT = 'Help could not locate this inline definition.';
function InlineDefNotFound() { alert(L_UNDEFINED_TEXT); }
function AppendPopup(oSource, sPopup)
InitializeGlobalData();
if (typeof(allDivsInPage) == 'undefined' || null == allDivsInPage) return;
var theDiv = allDivsInPage['divInlineDef_' + sPopup];
if (typeof(theDiv) == 'undefined' || null == theDiv)
InlineDefNotFound();
return;
if (theDiv.style.display.toUpperCase() != 'INLINE')
theDiv.style.display = 'inline';
else
theDiv.style.display = 'none';
var strAssetVersion = '0';var strGoDisplayCountOK = "Remaining characters: {0}";var fDisableCounter = false;var fDisableCounterFirst = true;var fWasLastCountOver = false;var fIsSimpleFeedbackWiz = false;var fIsOn2Lines = false;var strGoDisplayCountOver = 'You entered {0} characters. Please enter {1} or fewer characters.';var strGoDisplayCountOverStar = '* ';var strErrorCommentTooLong = 'The text you entered is too long. Please do not type more than 650 characters.';var iFeedbackWizStarRated = 0;var iRvasap = 0;var fFeedbackWizJustRated = false;var strYouAreNotOnlineErrMsg = 'You are not online.';var strPageAssetId = 'HP100704801033';var strFeedbackPageUrl = 'http://office.microsoft.com/assistance/fbk.aspx';var strPageLoggingParams = 'CTT=98&Origin=HP100704801033';var strCommentOnThisTemplateLnk = 'http://office.microsoft.com/en-gb/suggestions.aspx?AssetID=HP100704801033&Type=0&Rating=0';var strCannotSubmitFeedbackErrmsg = 'Your feedback could not be submitted.';var rgStrClickToRate = new Array(5);rgStrClickToRate[0] = 'Click to rate: 1 out of 5 stars';rgStrClickToRate[1] = 'Click to rate: 2 out of 5 stars';rgStrClickToRate[2] = 'Click to rate: 3 out of 5 stars';rgStrClickToRate[3] = 'Click to rate: 4 out of 5 stars';rgStrClickToRate[4] = 'Click to rate: 5 out of 5 stars';var rgStrYouRated = new Array(5);rgStrYouRated[0] = 'You rated: 1 out of 5 stars';rgStrYouRated[1] = 'You rated: 2 out of 5 stars';rgStrYouRated[2] = 'You rated: 3 out of 5 stars';rgStrYouRated[3] = 'You rated: 4 out of 5 stars';rgStrYouRated[4] = 'You rated: 5 out of 5 stars';
SOURCE: Validation using Excel VBA code
Thats a lot of form work to be expecting out of Excel. You might be better off using Access, creating a table. If you need to export it back to a spreadsheet you can. The validation controls are better in Access and don't have a lot of limitations to them.
Good luck on that
Excel Workbook
.xlsx
The default Excel
file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets
(.xlm files in Excel 4.0).
Excel Macro-Enabled
Workbook
.xlsm
Uses the same basic
XML format as the Excel Workbook, but can store VBA macro code. Users saving
an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in
Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file
format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro
sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled
Template
.xltm
Can contain a
VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Workbooks created from this template inherit the VBAProject part or Excel 4.0
macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental
program that runs additional code. Excel add-ins use the Open XML file format
to store data, and they support using VBA projects and Excel 4.0 macro
sheets.
