This is due to the fact that the safety tab on the tape is not present or is switched to lock . This is to prevent accidental recording on the tape. However if you had tried with a new tape and the fault seems to come then the fault can be that the trigger switch on this detector circuit is shorted or is accidently pressed to be ON. You can remove the tape cover and check this switch , if not there is fault on the controller section .
