Check the cooling fans inside the amp i suspect that they are not working properly and this causing it to overheat which will shut it down via a thermistor to prevent damage
thank you, I will check it out...hopefully that's all it is!
Looks like there is no cooling fan for this amp, according to the crutchfield website.
well its a heat sink problem or a faulty ****** so it may pay you to fit a cooling fan ,before you blow something and need a new one ..more expense
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
