Computers & Internet Logo
JOHN PIKE Posted on Aug 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just bought a Verbatim 4GB PinStripe USB Drive. My Windows 7 computer at home will not recognise it, and nor will most computers at work (Windows xP Professional). The shop replaceed it, but the problem persists.
File Repair Services
Level 3:
  • Master 827 Answers
  • Posted on Aug 16, 2011
Master
Level 3:
Answers
827
Questions
0
Helped
296195
Points
3317
Hello John,
The Store 'n' Go PinStripe USB Drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
Suddenly stopped working
Finaly some onformation, did you try another usb-port?
Driver VERBATIM 16GB BLACK PINSTRIPE USB
What is your question? Also, do you mean USB "drive" or "driver"? Please supply more detail.
Purchase 5 new verbatim 4gb when i plug it into pc the system found new hardware and installed . then it allow me to used two of the drive. when i plug it in the pc a msg appear, u need to format the disk...
You have to format the drives. If you put data on the drives using computer 'a' whos OS is MacOS and then you put the same Drive into computer 'b' which has windows, it may not recognise the file system/structure.
2answers
How do you unlock a verbatim 4 g pinstripe usb drive
right click on the drive and click format or re-format, this should erase everything on it and unlock it, but does not always work!
2helpful
I have a 4GB data traveller which is not recognised by any computer which I have tried i.e. XP & Windows 7. The error message is "USB device not recognised"
Your flash drive seem to be faulty,because you try it on more than one computer and you get the same problem,you should replace the flash drive.
New computer with windows 7. old one is xp flash verbatim drive is not recognised.
File Format is the same... should work.... try the USB Ports in the Back... or it maybe a 1.0 Flash Drive that is not supported anymore.
Usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
My ped drive kingston datatraveller 4gb doesnot work in win98
I think you will find that the card works fine but your computer doesnt recognise the card reader properly. Windows 98 does not properly recognise most usb devices but Windows 98SE does although I am not sure if it will recognise usb2 properly.
5helpful
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Top Verbatim Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Obehiaghe Adoghe
Obehiaghe Adoghe
ExpressFiX
ExpressFiX
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
