Columbia Telecommunications Group FRS 22 WH (22 Channels) 2-Way Radio Logo
A
Anonymous Posted on Dec 05, 2005
Battery charger where is the location for battery charger plug in the watch radio model FRS22-HH
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
214
Points
Location to charge batteries for COLUMBIA TECH.2-way watch model # FRS22- WH is under watch band. remove the buckle side and its right there.
Anonymous
Level 2:
  • Expert 215 Answers
  • Posted on May 22, 2006
Anonymous
Expert
Level 2:
Answers
215
Questions
0
Helped
241755
Points
430
Take a look at the plug on the end of the lead which comes from the charger then see if you can see a corresponding socket somewhere on the watch. You may have to remove a small plastic or rubber cover to find it or it may be behind a small door. It's got to fit somewhere, just keep looking. BMW
2answers
What is the polarity of the jac/mic so I can charge rechargeable batteries by ACDC adaptor
On you're AC adapter unit, there should, if it's a good one, have a switch with a + & - signs indicating the polarity you require to use.
Further to this, does your radio have an AC recharge point. Some of these units don't have this capability, but in your case it may.
This is usually found on the side of the radio.
If there is no such point, then what you need is to buy rechargeable batteries with the appropriate charger, you can't just use any charger for these batteries, else you'll damage them.
I hope this helps you.
Best regards,
Peter
1helpful
Have pair of FRS14ND radios, with charger. One battery pack has quit, so other must be about to. Tried switching remaining pack between radios & both work, so it's not radio. Can't get AAA alkaline...
Similar problem, solved when dirty contacts were cleaned, look for some corrosion on either the battery pack or in the radio battery holder. Use very fine grit sand paper.
also check to see if a tab on the battery holder contact is bent inward (radio dropped perhaps)
Hi,I need a replacement battery pack for my Sitex handheld VHF HH-250.Thanks Original 8N-600
What you need is at the VERY least is a Ni-Cd battery pack with 600mA/hr rating. We have an HH-300, with a configuration of 4AAx2.
Interstate Batteries has the BEST price I could find, although when we bought the HH-300, I sent it to SiTex for a new battery AND a tune-up which cost around $100.
Here's the link to the Interstate battery website.
<a href="http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-NIC0068(Other+Products).aspx?dsNavigation=Ntk%7eSearchGroup%7cSitex+HH%2f-250%7c3%7c%2cNy%7eTrue%2cNtpc%7eDisabled%2cNs%7eproduct+Type%7c101%7c1%7c&Title=9.6V+800mAh+NiCd">http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-NIC0068(Other+Products).aspx?dsNavigation=Ntk%7eSearchGroup%7cSitex+HH%2f-250%7c3%7c%2cNy%7eTrue%2cNtpc%7eDisabled%2cNs%7eproduct+Type%7c101%7c1%7c&Title=9.6V+800mAh+NiCd</a>
Hope this helps.
(EDIT)
Do NOT forget that these radios are wired center pin negative! (Don't ask how I found this out...)
3helpful
Cobra HH 40 charger specs
I have a Cobra HH-40 CB radio and am charging it as I type. The included charger is rated at 16V DC, 100mA. The pattery pack charges 10 AA rechargable batteries (the manual specifies NiCd, but you can also safely use NiHM). The 12V DC car charger included cannot be used to charge the battery pack, but can power the radio.
1helpful
The voltage for charging and plug-in power, cobra hh35?
the voltage for the charging is 12 volts dc the charger is a 110 volt dc 12 volt to the radio if you lost your charger you can get a aftermarket at any radio shack store just be sure you take the walkie with you when you go so they can match up the rdio plug end.
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting.
Features:
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Manual and battery charger needed
I'm still looking for the manual (?).. it's more of a pamplet as I recall.
The battery charger is...
AC/DC Adapter Model 0750200DF
Specs are:
120 V AC 60 Hz to 7.5 /v 200ma
If you can't find the right adapter, you can probably get one of the universal adapters that will work.
I also recommend that you replace the batteries with "Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
for getting."
Much more talk time than the original batteries.
FRS-14ND 2 way radio
Hello you can recharge the batteries only if the bateries you are using are rechargables, this could be Bat recharg. 2AA or 3AA or a pack.
Top Columbia Telecommunications Group Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Columbia Telecommunications Group Radio Communication Expert? Answer questions, earn points and help others
