Ge should know their own codes. F2 for GE means oven control senses overheat over 600 degrees
Go here for code desciption . You should be able to fix youself
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes
best of luck
matt
We reset it and now the F2 does no flash, but the bottom heating element still will not heat?
Assuming your oven never actually overheated ,the control thinks it did and wont turn on the element .Don,t buy another element.There is a sensor that is probably to blame. Look for a probe in the back of oven. Part #WB20K5040(please double check with GE) $70
If you think your oven did overheat meaning over 650 The problem is bake element relay or the control (or ERC)
