Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
The lint filter is clogged preventing the pump from draining all the water from the tub. Open the little panel on the front lower left of the machine, unscrew the lint filter and clean it. Make sure you drain the trapped water first (before you remove the filter), by pulling out the little rubber hose (you'll see it) and removing the plug from the end.
