Series MP258 printer. According to my experience of Error P10 can be solved by replacing one or more of the following spare parts:
That is paper feed sensor problem...replacing main logic board is one of the remedy.. ;)
Error Code P10 in Canon Printer indicates a paper jam inside your printing machine. When a piece of debris gets struck within the printer rollers, you will encounter this crispy error. There are a series of a procedure to Fix Canon Printer Error P10.
Follow the Steps below to Troubleshoot Canon Printer Error Code P10 -
SOLUTION 1 - Try with Resetting the Cartridge Ink Counter.
Press & Hold the Resume & Power Button both at the same time.
Hold both buttons for at least 5-10 seconds.
Now, Release the Resume button.
Press the Resume button 5 times.
Release the Power button.
Once done, the blinking ink power light should go steady after a few seconds.
SOLUTION 2
First of all, you need to press the power button to turn your printer off.
Now, press & hold the Reset button on your printer followed by pressing the Power button.
Keep on pressing the Power button & thus release the Stop/Reset button.
Press the Power button twice & thus let it go.
Wait for around 20-30 seconds until & unless the LED shows.
At last, press the power button twice to eradicate Canon Printer Error Code P10 in lesser span of time.
I hope both these solutions will be helpful to fix Canon Printer Error P10.
Mark Wilson
You can Directly dial Canon printer customer service phone number (877)234-3909 to solve all the printer issues in a minute or visit http://www.oncalltechsupport.co/canon-printersupport.php
Berdasarkan pengalaman saya, bila terjadi error p10 di mp258 dan yang rusak boardnya jangan diganti dulu, coba periksa R dengan nilai 752 yang terletak dibawah solasi hitam, biasanya R tersebut putus, coba ganti R tersebut maka P10 akan teratasi. saya sudah mencoba di beberapa printer mp258 dan berhasil. semoga tulisan ini bermanfat
The print head voltage is abnormal. Replace the following items: - Ink
