We have a Toshiba tv and when we turned it on the picture has a yellow-green tint to the whole picture. We tried to correct it using the tint and other features but it still stays the same. We have also unplugged the tv from the wall hoping it would reset itself. Any suggestions? screen turns 3 d and concaves at top and bottom and gives a less than sharp picture
SOURCE: Mitsubishi 56231 Turns on but no picture or sound
Had set looked at by a tech. He told me he had to fix the video processing board & something with the power supply. I'm back on now, $350 later, but I worry that this is just the beginning of more problems to come. I would not recommend the Mitsu-DLP models. Poor quality workmanship &
NO SERVICE/SUPPORT!!!
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
SOURCE: green power light will not stop flashing and tv will not turn on or off
I'm having the same problem. Did this suggestion work?
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
on the inside of the tv, there is a circuit board with a metal cover over it. looking in from the rear, it is the tallest one and to your left. its where your usb ports are and also the digital audio ports.its tricky to get it out but once u do there will probably 4 capicators on one corner that will be swolen. they are bad if u see this. you will need 4 16volt 1000 uF(micro Farret) 105degrees c. once u have soldered them into place and are ready to install make sure u get the board in line tn the groves of the plastic line up tool that will still be attatched on the board, and make sure u get the panel conected. plug your tv in wait bout a min, the light dosnt go off reset and wait one more min. it this dosnt cure your problem you probably have a bad module. but if it does work you have a cheep fix. the capacitors are only about 25cents each on mouser.com, and anyone can buy from them.
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
