20 Most Recent
Toshiba 42HL167 42 in. LCD Television Questions & Answers
REGZA 42HL167 Won't turn on
I found it!
I managed to fix it by
reloading the firmware.
I posted detailed instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
I hope this is still useful for others. It's so embarrassingly easy anyone can at least TRY it before calling a tech if they have any friends that are computer savvy.
-Ben
42hl167 no picture but has sound
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Brand toshiba lcd model 42HL167
This could mean that the tuner board is bad. By saying "no image", does that mean that there is snow on the screen (i.e. from no signal received), or simply a black background or distorted image from bad reception? If the menu is displayed than that means that the image driving circuitry is working correctly.
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
