Zyxel P660HW-D1 Router Logo
Posted on Aug 09, 2011
Disable sip alg on a P660H-D1 - Zyxel P660HW-D1 Router
M phone wont call out.. it has a constant dial tone ..can you help me?
Might be a firewall setting in your router. See if you can change the SIP ALG setting. If it is off, you need to turn it on.
Here is a site that will help you identify the SIP ALG in your router:
http://www.nextiva.com/support/how-do-i-identify-sip-alg.html.
1helpful
Hi i want to disable the input panel popup keyboard but whenever i try it keeps popping back on screen how can i disable this?
If the problem is in internet explorer go to View, Internet Options, and on the advanced tab check the box that says "Disable automatic SIP"
Is that mean D-Link DVG-G1402S router does not support VPN Server?
IT does Security • SIP Authentication with Password Encryption • Configuration Download Using HTTPS and SSL/TLS Clients Certification Encryption and Authentication • VoIP NAT Traversal (SIP/STUN) • NAT/Firewall (NAPT, TCP/UDP, DMZ, ALGs) • VPN Pass-Through • Packet Filtering by IP Address, Port Number, and Protocol
2answers
My nat type is strict and when i try to play my PS3 i have connection issues. How would i get my nat type to be open?
Zyxel routers don't support Nat 2 confirgurations for the PS3 software. You can fix some issues by powrforwarding the speciffic ports that the PSN uses. To do so follow this ismple guide:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/PlayStation_Network.htm
It may vary from game to game so you should choose what speciffic product are you trying to use here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
2answers
Disable SIP AL
connect to the modem through telnet and type
application unbind SIP 5060 saveall
Audiocodes MP118 8 FXO early media to Freeswitch SIP extension
Hi, man.
There are many things to consider in this type of application.
when calling from PSTN to IP using analog lines from time to time you will have this type of event, I suggest working with H323 protocol, this will tone down a bit your problem.
If you want optimum performance, you should use a DID with the channels you need and address to your PBX SIP FreeSwitch. The DIDs are cheaper and are digital which eliminates random connectivity problems in the incoming call.
Once you have directed the DID you tell your server to transfer the call to the IVR using your internal dialing plan.
Lucky
ZyXEL P660HW-61
while your computer is directly connected to the router, try to change the channel to 1,6 or 11. Try to enable wireless security and disable firewall on your computer. try to turn off other wireless device that may cause interference on your network
15helpful
4answers
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
