These type of refrigerators can not be simply recharged as there is ammonia inside and not freon.
The cooling units can be replaced tho. Most systems can be changed out in a matter of just an hour or two. Our Replacement units come standard with install instructions and a lifetime warranty. Check out our online Store
Toll Free ph 1-888-782-6665
check out our video on how to change a cooling unit
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
If you can hear it running and it sounds like it is gurgling or boiling then it is you cooling unit that has leaked. Your cooling unit is charged with hydrogen and ammonia. When the hydrogen leaks it causes the ammonia to boil more rapidly, hence what you hear. You will require a new cooling unit for your refrigerator. This is something that can be done by anyone in just a few hours with no specialized tools needed. You can give Arcticold a call toll free (1-888-782-6665) or check out our online Store I have also attached a how to video for the installation of a Arcticold New Lifetime Warranty cooling unit.
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620
Any sign of yellow residue on the rear of an RV Fridge means that you require a replacement cooling unit. It is something that can be done by most RV owners. Ive attached a video that will walk you through the install of your cooling unit. The video is by ArctiCold Refrigeration We keep it cold The cooling unit can be purchased aftermarket at Arcticold's online store. www.arcticoldstore.com Store
