20 Most Recent Century 80GS Flux - Cored Wire Feed Welder Questions & Answers
Welder will only weld for about three inches on high
If it won't push wire through gun you might need to tighten wire rollers, or check the liner for bad spots.
8/26/2010 1:55:17 AM • Century 80GS... • Answered on Aug 26, 2010
Difficulty changing the wire
check the tension on your drive rolls. Also check if the drive rolls are correct for that wire size.
7/1/2010 8:55:26 PM • Century 80GS... • Answered on Jul 01, 2010
Would like to weld quarter inch angle steel
You have to check the capacity specs on the welder. To weld 1/4" I would find one that welds up to 3/8"
8/27/2009 12:17:31 PM • Century 80GS... • Answered on Aug 27, 2009
Trouble feeding new wire through tip
1. Make sure that the new wire is properly locked down in the advance roller. There are grooves in this and the wire must fit in the groove.
2. Make sure the wire is properly lined up to enter the gun cable (after the roller)
3. Remove outer shield on gun and the center tip and then advance the wire until there is a few inches sticking out, then slide tip back over the wire and install the tip and shield.
6/2/2009 3:35:51 PM • Century 80GS... • Answered on Jun 02, 2009
I have an Inca 343.190 planer / thicknesser with a problem: the in-feed and out-feed tables are not parallel, but I can't find any advice on how to adjust these tables. Can anyone help please?
The best resources to answer this would be the maker themselves, or the woodworking / machine forums. Details in the link. https://www.google.com/search?q=inca+343.190+manual
Automatic Planer jointers thicknesser 343.190 - Inca Parts ...
Incamachines https://incamachines.com > english > inca-spare-parts > a... 343.190 planer thicknesser plane jointers US models 510, 550, 570.
INCA Woodworking Jointer Planer
Machine Atlas https://docs.machineatlas.com > Inca+Woodworki... PDF The INCA Woodworking. Machinery Handbook. With useful tips and jigs for everyone. Mark Duginske, Karl Eichhorn. ????. Edited by INCA Ltd, Teufenthal/Switzerland . ..
4/19/2024 7:07:51 PM • Tools & Hardware... • Answered on Apr 19, 2024
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
3/18/2024 5:15:05 AM • Tools & Hardware... • Answered on Mar 18, 2024
Vibrapower Disc model BW-5040 exercise machine. E4 flashing on a Vibrapower disc model 5040. Replaced power cable
Question edited for clarity and typos. Question moved from Office Equipment category. It appears to be an unknown machine with no support and only mentions of people selling them. https://www.google.com/search?q=vibrapower+disc+5040+E4+error https://www.google.com/search?q=vibrapower+disc+BE-5040 A manual will often lead the the maker. https://www.google.com/search?q=vibrapower+BE-5040+manual ..
2/2/2024 1:34:19 AM • Tools & Hardware... • Answered on Feb 02, 2024
2answers
Where can I get replacement parts for my Tradesman BD460VM belt sander?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=Where+can+I+get+replacement+parts+for+my+Tradesman+BD460VM+belt+sander%3F
12/5/2023 10:35:53 PM • Tools & Hardware... • Answered on Dec 05, 2023
2answers
How to load a black and decker staple gun model dn418/d16
What width staples go in this gun ?
I have a box of T50 staples here labeled 5/16 , 8mm, but they are too narrow when dropped in to the channel in the stapler.
11/12/2023 6:22:42 PM • Tools & Hardware... • Answered on Nov 12, 2023
110v Milwaukee m28 battery charger was plugged into 220v outlet and not working
In this case, it's possible that the charger has been damaged and is no longer working properly. I recommend contacting Milwaukee customer service for further assistance. They may be able to help you troubleshoot the issue or provide you with a replacement charger if necessary. Here is their contact information: Phone: 1-800-SAWDUST (1-800-729-3878) Email: [email protected]
10/28/2023 7:18:44 AM • Tools & Hardware... • Answered on Oct 28, 2023
2answers
Removal Storage
If you are looking for a company who use latest equipments then i would refer you to appoint "bison removals" or "guildford removals". These two companies have excellent instruments to make your removal effortless.
10/4/2023 9:00:49 AM • Tools & Hardware... • Answered on Oct 04, 2023
Tacwise 191EL Pro Electric Nail / Staple Gun will not fire nails, it just clicks.
Question edited for clarity and toss in some CAPS. Usually caused by a jammed nail or staple. https://www.google.com/search?q=tacwise+191+el+pro+jam ..
9/19/2023 5:03:37 AM • Tools & Hardware... • Answered on Sep 19, 2023
Woodtek WK-2 Shaper. Looking for a manual for it please.
Question edited for clarity. No manual except with a used machine. The first link says who the distributor is. https://www.google.com/search?q=woodtek+wk-2+shaper+manual ..
9/13/2023 6:32:24 PM • Tools & Hardware... • Answered on Sep 13, 2023
Century 80GS Flux - Cored Wire Feed Welder Logo
11 questions posted
Top Century Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Century Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Century Tools & Hardware - Others
Most Popular Question
like weld quarter inch angle steel
  • Tools & Hardware - Others
