20 Most Recent Bowflex Selecttech Dumbbells Questions & Answers
Bowflex Select Tech will not come out of base. Is
One of the weights is most likely a little off in the base. To unstick, remove the four screws on the base, then the two screws on clip. Handle will then remove.
3/26/2020 2:41:05 AM • Bowflex... • Answered on Mar 26, 2020
3answers
The selecttech dumbell adjuster will not move. It
Push the button on the bottom of that releases the adjuster to spin. Set both to sides to 5, put all the weights back and your ready to place it back and select a weight.
1/25/2017 1:03:19 AM • Bowflex... • Answered on Jan 25, 2017
0answers
0answers
0answers
0answers
0answers
When selecting a weight the
This generally happens when you match a larger weight on one side with a smaller weight on the other side of the ********, and usually can be fixed by just equaling out the weight and trying it again. Or remove the Dumbbells from the base and remove the plates from the base until the base was completely emptied. Then, with the emptied base, place the Dumbbells back within the base (without remaining plates on the floor). You should be able to switch the dials back to 10 lbs with plates from the Dumbbells coming off. Then simply place back all the plates within the base and place the DB back within the base with the plates ready to go. The Dumbbells should pick the plates right back up.
7/27/2013 8:50:26 PM • Bowflex... • Answered on Jul 27, 2013
How to take the handle apart
There is a great video on this on YouTube
6/10/2013 6:02:37 AM • Bowflex... • Answered on Jun 10, 2013
Bowflex Select Tech was dropped and the plastic frame broke. Can it be fixed?
two of the plates have broken, the plastic nipple that holds the plates to the handle have broken off. therefore, the plates do not stay connected to the bar. will bowflex send me new plates? can i send them back and have those plates repaired? or do i have to purchase replacement plates, if so, please share...thanks!
8/6/2012 10:55:28 PM • Bowflex... • Answered on Aug 06, 2012
Bowflex Selecttech Dumbbells Logo
54 questions posted
Top Bowflex Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Bowflex Sport & Outdoor - Others
Most Popular Question
  • Sport & Outdoor - Others
