20 Most Recent
Samsung G810 BLACK 5MP WIFI 3G camera mobile phone Questions & Answers
My siemens mobile is not working however i changed
If the charger and the battery is new and the set does not power, then it is possible that the mother board is faulty.
Since these are highly intergrated circuits it is not possible to replace components unless you are well equipped with soldering stations and testing equipments. So please refer to service and get estimate.
How to reset my samsung
Welcome to FixYa
From your keypad Type #*7337# or try this to hard reset *2767*3855# or *2767*2878#
It will ask you to confirm, Press ok & if ask phone code then Default phone lock code for samsung if it did'not changed before then it is 00000000 (eight zero's)
Note: Remember one things hard reset will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then format it
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks
I can't take aphoto on my phone
HI,
There are the many reasons for this.. a proper examination will reveal the exact cause... but the most common reason is the corruption of the software... Therefore, It is advisable that the you first update your software and then also the problem persist then get it serviced because the problem may be of Motherboard or IC...
Hope this has helped you..
Thanks...
My phone freeze
i have forgoten my samsung phone password. can u plz... help me
My phone won't turn on and it won't charge.
hi im josh in cebu phils.may i help you friend?
The phone is not charging until now it does'nt on. Friend the problem is the chargin pin the current cannot pass through in towards the batt thats why the phone wont power any more if the battery is already empty.. you need to replace the charging pin. you can buy it in some mobile phone service center and try to browse this site for further help in disassembling the unit
here:
http://www.streetdirectory.com
good luck hope i helped you.
