20 Most Recent
GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPO2 Questions & Answers
Simultaniusly on and off
hi,
You have to check the battery of you monitor . If the battery is short then this problem can occur.
ok
I need the service password to reset the unit to
hi,
remove the AC power. then remove the battery from the machine. reinsall the battery after 15 minutes. then power on. it will be at factory settings. if u need its service manual pls contact me through fixya . for removing battery watch the pictures bellow.
ok
I HAVE AN EAGLE 4000
Most likely a bad battery which made the system loose the software. Small chance that the screen is bad. If you connect a pulse ox and you hear the hear rate it is a bad screen. If you don't hear it you will need to get a copy of the software and a new battery. GE does not support these anymore so you should contact a third party if you are not able to do it your self.
If you have further questions you can contact me at
[email protected] or through our website www.overstockme.com
It keeps rebooting
when the battery goes completely dead it looses its software. The only way to fix this is if you have a copy of the original software and install a new battery. With these units it is a good idea not to leave them unplugged for a long period of time. It is a good way to loose all the data.
[email protected] or through our website www.overstockme.com. We have a biomed on staff with 25 years experience who is able to fix this issue.
Service password
we have no way to provide any kind of password assistance, this info must come from the support center for the product.
Interpretation is missing on GE Mac 1200
If your GE Mac 1200 ECG machine is not printing the interpretation, even though the interpretation option is marked as "Y," there may be a problem with the printer, the cables, or the settings.
To troubleshoot this issue, you can try the following steps:
- Check the printer to ensure it is turned on and properly connected to the ECG machine. Make sure the cables are securely plugged in and not damaged.
- Check the printer settings to ensure the interpretation option is enabled. You can do this by pressing the "Setup" button on the ECG machine and navigating to the "Printer" menu.
- If the printer settings are correct, try resetting the ECG machine by turning it off and then back on again. This may clear any temporary glitches or errors that are preventing the interpretation from printing.
- If the problem persists, you may need to contact GE customer support for assistance. They will be able to provide you with more detailed troubleshooting steps and help you resolve the issue.
12/10/2022 5:09:43 AM •
GE Medical
Answered
on Dec 10, 2022
GE mac 1200 printer rolls opposite direction. why?
If your power line has a two female connection, try unplugging and turning it over ( so the connections are the opposite way around ) plug it back in and try it again, sometimes the current will only flow one way and if it's wrongly connected it will cause the motor to run in reverse.
Jayel.
4/10/2017 8:32:29 AM •
GE Medical
Answered
on Apr 10, 2017
I have EKG machine GE
Our EKG machines at work have specific paper that will only work with them, are you using the same type as before? Also, it is possible to put the paper in upside down and it will not print on that side. Have you tried to turn the paper around? Good luck
11/15/2011 10:57:17 PM •
GE Medical
Answered
on Nov 15, 2011
